Question about Sewing Machines
Bernina 1031 Having problems with feed dogs getting stuck in the down position. Will pop up with help but not with the knob. Had it serviced by a bernina service tech and it worked for a while. Now it is happening again. What can the problem be?
  • jjsm4 Apr 24, 2008
    Already cleaned the machine **** and span before contacting you. Also oiled the bobbin case where my book says to. I can hear and feel the knob turning properly, it just isn't catching the innards to flip the feed dogs back up. I have no problem taking it back in to the shop, but if the man claims to have fixed the problem, why is it happening again?
  • Jazzy Fran Cappetta
    Jazzy Fran Cappetta Mar 29, 2017
    some thing happen to me just had my service a few weeks ago cant find where to left my feed dog was sewing happily then it stop moving .
  • Sewing Machines Master
  • 1,388 Answers
Remove the needleplate and check for a buildup of lint between the teeth, this is the most likely scenario.....clear out all the other lint while it is open, and do it regularly.
A small brush and vacuum cleaner are useful, just remove the bobbin case etc first !!
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 24, 2008
  • Hassy
    Hassy Apr 25, 2008
    The feeddog mechanism is dis-engaged via a slide switch, usually near the bobbin case/hook race on a front loading machine, for a top loader they tend to be near where the free arm joins the main body and may be at the front, or rear.
    When the feeddogs are dropped for free motion quilting, the cam is dis-engaged until you raise the feeddogs again........it is then necessary to rotate handwheel one complete revolution for the cam to re-engage, thus raising feeddogs.
    If this is not happening, there is a problem
    1. in the spring which normally re-engages the cam, or
    2. the cam is otherwise obstructed, possibly by debris (pins, needles, lint etc)
    3. the spring is broken, or
    4. there is too much friction between the shaft and the cam collar for it to restore the correct position.....grit, lint and old oil forming a glue.
    ....in other words, a mechanical problem.
    I have only been able to find a very small image of this model and would guess it to be a front loading bobbin.
    It also appears to have a front & rear 2 piece moulded case rather than top, bottom, front, back and sides.....tricky to gain access and not recommended without a service manual as there are a multitude of hidden screws and plastic clips that are easily broken.
    If this is within the 90 days normally associated with a service warantee (or 12 mths for a new machine) and has been ongoing since the service, I would suggest a phone call to arrange to meet with the technician ASAP to show them what you are experiencing....even if it slightly over the 90 days, they ought to have a look for you, it is your ongoing business they will be keen to attract and good service is not only good business, it is good for business.
    This problem really needs someone to look at the mechanism on the bench in my opinion, and any more email suggestions I may offer for "busting it open" to fiddle around inside may do more harm than good.
    Best wishes for a speedy resolution.
    just fixed it .knob at bottom was to the left and had to move it to the right and turn wheel
My Bernina 440 QE feed dogs won't come back up. Lowered them and now when I push the button they will not re engage.
Try turning the hand wheel through a full rotation. Do this after you press the button and it returns to the engage feed dogs position.
This works on many sewing machines. If the feed dogs remain down, then you may need to have the machine serviced. There is a possibility that a part broke or a linkage is stuck between the button on the hand wheel and the feed dogs.
I hope this helps.
Jul 29, 2017 | Bernina Sewing Machines
Where is the feed dog lever on my bernina record 830 sewing machine
On the Bernina 830 Record (older mechanical model), it is usually the very bottom knob on the right side (directly below the Stitch Length Lever). It should turn right or left about a quarter turn to switch between feed dogs up or down. If the knob is frozen, then it has seized due to old dried oil (a common occurrence with older mechanical machines that have not been serviced regularly). Stuck feed dogs, stitch selectors, buttonhole knobs, and the handwheel are some of the most frequent victims of seizure. However, with lots of patience, time, fresh good quality sewing machine oil or liquid Tri-Flow Synthetic Lube, elbow grease and a handheld hairdryer, these issues can usually be successfully addressed.
Wheel on right side that controls the needle up and down is very tight...
Jan 13, 2017 | Bernina Sewing Machines
How do I lower and raise dogs on the bernina 1008
unless there is a mechanical failure , the feed dogs are governed by the forward/reverse control
if it is in neutral position then the dogs will not move
Oct 27, 2015 | Bernina Sewing Machines
I have a bernina sport 801 and the fabri feeder
There is a small knob on the lower part of the main body under the stitch length lever. This controls the feed dog up or down. Make sure that it turns easily and fully to both positions. If it does and your problem persists, the feed dog height adjusting point is probably loose. A knowledgeable repair person needs to look at it. It is not a difficult repair, but several approaches need to be taken.
Jan 09, 2010 | Sewing Machines
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Jan 26, 2009 | Bernina 1008
Feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
May 07, 2007 | Singer 2662
Sewing Machines Logo
382 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
