Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
My installation disk is faulty..
Have tried to find a download to install but can't find one!! Can you help please?
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 11, 2009
Please advise set up / installation for Netgear WPN824 without CD
Posted on May 01, 2008
    Sergeant:
    Champion:
  • 427 Answers
Your router actually works better without the installation disk because the program on the cd is actually known to be very controlling. If it is setting up your router you are having trouble with, send me a message of call netgear.
Posted on Apr 24, 2008
My hp desk tip says " Disk boot failure insert system disk and press enter" Please help what to do.
Your hard drive may be faulty, this is why the Windows operating system not found.
Go into the BIOS and see if the hard drive is detected, if not reseat the hard drive and boot up again.
If the Windows operating system not found then most likely the hard drive is faulty and to get the Notebook working again, replace the hard drive, install Windows on the new hard drive plus the HP desktop device drivers and your programs.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Jul 14, 2011 | Computers & Internet
I am trying to re-install my pixma 600R but each time i get to 44% 13 min it stops. I have disconnected firewalls and follwed suggestion in manual. Can you please help. Many thanks. kev
Hey,
You may have a faulty install media, I will get you a download to the setup program in one minute and you can try installing with it.
Sep 11, 2008 | Office Equipment & Supplies
Printer will not install
Hello. Thanks for choosing Fixya! Click on your start button and then on printers and faxes. Look and see what other printer drivers you already have installed. Delete any that you no longer need and THEN install your new disc. Regards, Joe
Nov 12, 2009 | Office Equipment & Supplies
When installing hp 4400 photosmart all-in-one in my laptop "fatal error" appears at 94% installation. No help have I found. Help, please
This type of error usually happens as a result of a faulty disk or security software blocking one of the installers script files.
to get around a faulty disk go to:
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us&h_lang=en&h_cc=us&h_query=photosmart+4400
select the exact model you have then download the drivers from hps site for your version of windows and then install. If this works you are done.
If it again fails near the end you can try download just the basic driver to see if it's the driver or the security. If that doesn't work you can try temporarily disbling your security software (antivirus), or try using a logon account with higher priviledges such as the administrator account.
Either way once you have tried the downloaded software add a comment here and I will follow up with you if the first suggestion did not work.
Hope this helps FixYa,
Chris
May 05, 2009 | Office Equipment & Supplies
Hard disk Error, Please help!
If the BIOS cannot detect the hard disk then you most likely have a faulty hard disk.
You need to purchase a new one.
May 03, 2009 | Acer Extensa 4620 Notebook
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
Installing all in one on my computer!!
Try reinstalling the software or it maybe a firewall causing it not to be allowed so please check that. Also maybe that you have a faulty installation software disk you can download the software from www.lexmark.co.uk or lexmark.com
I hope this is of some help to you
Thanks J
Jan 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
64 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
