Question about Dell Dimension XPS PC Desktop
Monitor goes into energy save
I have a flat screen monitor and when i am playing gcertain games like call of duty 4 , my monitor goes into energy save mode and then says it is not receiving any signal
I have the same issue, I Have to restart pc by holding the power button. I have been told it may be a over heating issue? and did have a noisy fan but this apears to still be going round though not very fats. have you resolved you problem?
Posted on Jan 30, 2013
  • 58 Answers
Try going into the controlpanel,display,then on the screensaver tab click on the power button and check settings
Posted on Apr 23, 2008
I have a Dell Dimension e521 desktop that has gone into energy save mode after I ran Norton security check.. Pressing any key or clicking the mouse doesn't do anything. The screen is black and says...
you may find you have the screen resolution set to high, try changing to 1024x768 and try again. if this works it means your monitor ain't up to the job of your better machines.
Nov 15, 2013 | Cars & Trucks
Dark Screen
there is a weird possibility that somehow your PC is configured to save power.. that is something you can do on a laptop to save battery..
you can check in the control panel what is the status of your energy options and see whats going up there..
there is also another possibility that it might be the monitor to be malfunctioning... but if after the screen being dark and you enter the options on the monitor and they are bright i doubt its a malfunctioning monitor..
so try to reinstall the monitor drivers and possibly the drivers of your video card if you have one.. but my biggest bet would be the option energy in the control panel
Dec 22, 2007 | Gateway FPD-1930 19" Flat Panel LCD...
My screen goes black when playing game
try this & see if it helps
Monitor settings for windows 7
1. Start menu
2. Control panel
3. Hardware & sound
4. Power options
5. Choose which settings you want & then go to the change plan settings
6. Choose which setting you want to run your monitor
7. Then save changes
Sep 10, 2012 | ASUS Computers & Internet
My HP W1907 monitor works fine until I try to play The Sims 3 game. I play for several minutes or hours and the monitor shows the message that it is going to sleep and the light on the monitor goes...
Hi there. I had the same problem months ago when I try to play high end games like Sims 3 my monitor goes into power saving mode. I tried to check every possible causes of the problem. It could be that your computer is overheating try to clean your computer and check if your fans still works. Second it could me your power supply malfunctioning, maybe it does not meet the required power to make your game work. Last cause is your video card malfunctioning, what I did is to just buy a new video card and it works.
If you do not have spare power supply or video card you can go to a computer repair shop for them to check the possible problem that causes it to go into power saving mode. It can also save you money before you can buy a new one.
Hope this helps, Have a good day!
Oct 03, 2010 | HP w1907 LCD Monitor
Can't get monitor out of energy save mode
you talk about a dell monitor but categorised under LG monitor... if it's a Dell monitor, and its recent, it's possible you've put it in analog/digital mode when you need the other mode. push the left button on te front of your screen that should switch your screen from digital to analog or vice versa
Dec 28, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Analog Power Saving Mode Problem!
Have you checked you power saving options in Control panel.
If this is a desktop, unless you are a energy miser, I would change your power saving options to never on all options, turn off hibernation and suspension for when you are playing games.
You can find this in control panel under power Options.
Let me know if this helps.
Thank you
May 18, 2009 | LG 22" FLATRON LCD Monitor
Flatron L1953S Goes to power saving mode while playing..
I had the same problem with my LG Flatron (not the same model as your one). I fixed it by connecting both the digital and analogue cables from the pc. Presumably, the problem occurs because the monitor is not receiving a digital signal.
Mar 18, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Graphic problems
first problem
ur monitor start blink bcoz the graphic cards does not support ur game i.e call of duty world
Do this steps
first remove ur card clean with soft cloth & insert in ti slot than afterwards reinstall the game than also the monitor blinks than the same case as above i have mentioned
second problem
reinstall the crack of chronicle
or update the registration of the game
if problem occurs than the game has not been installed properly
Dec 04, 2008 | XFX GeForce 6200 Graphic Card
LG FLatron W2252TQ Not working properley in DIgital mode.
Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
blog.lopau.com/fixing-power-problems-with-your-lg-flatron-monitor-lg1753s/
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Mar 21, 2017 | Computers & Internet
"Desact.monitor"
my monitor says desact monitor and I dont know what it means.
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Dell Dimension XPS PC Desktop Logo
70 people viewed this question
Alun Cox
