Question about GE 46GW947 46" Rear Projection Television
Convergance chip the chip on the board i found was a stk 730-130 says its a regulater chip do you know where on the chassis i would find the convergance chip ? thanks
  • GE Master
  • 8,617 Answers
Thats the regulator chip for the convergence circuits thats the one youre most likely needing, as your chassis doesnt have convergence ICs. You can get that IC at the following link and they will provide free installation instructions and free on line tech support just in case you need assistance. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Apr 23, 2008
Convergance chip
devices: Any Projection TV with a Convergence Amp board
If I knew which Mitsubishi Projection TV you're looking at, I could help quite a bit more. In general, the "convergence chips" on a typical Convergence Amplifier board are actually two STK's mounted to large heat sinks. "STK" is electrical engineering slang for "Convergence Amplifier Integrated Circuit".
Here's a helpful Solution archived at FixYa:
http://www.fixya.com/support/t4337218-image_bowed_line
You'll see in the photo that the STK on the PC board actually have part numbers on them that begin with "STK".
Dec 09, 2011 | Mitsubishi Televison & Video
Mitsubishi 55" Convergence chip location? Where
Look for a big heat sink (big piece of aluminum) right behind the back access panel. The brown pressboard that you need to take of to have access to the inside of the chassis. I think there is two STK chips for this tv. Older mits only had one. The STK chip is black, should be about 3" long with about 20 pins on it. It may have a metal clip covering the part number on the front.
Feb 19, 2011 | Mitsubishi WS-55711 55" Rear Projection...
Toshiba 65hdx82 convergence issues
check fuse resistors near STK, and broken PCB around digital convergence board (board in a metal box verticaly mount beside STK.
Apr 23, 2010 | Toshiba 65HDX82 65" Rear Projection...
Mitsubishi WS-55859 55in Rear Projection CONVERGENCE won't correct
HELLO YOU FIRST NEED TO UNPLUG THE SET , THEN TAKE OFF THE BACK OF THE SET. AND LOOK FOR TWO LARGE SILVER HEAT SENK'S THE IC CHIP'S WILL HAVE STK-393-110 ON THEM.!!! WILL BE SCREWED TO THESE HEAT SENK'S WITH SCREW'S AND SOLDER TO THE BOARD ON THE BOTTEM OF THE BOARD,!!! WELL "GOOD LUCK"
Nov 09, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Convergence Board (I hope)
check this out I have the same problem check your solder spot make sure the solder points are not touching one another, that could be one of the reason is doing this or just to make sure you can desolder the stk chips clean the holes where the pins go trough the board and power the tv with board and if the tv start fine if could be bad stk chips be very careful when desoldering or soldering good luck about another is not worth it they cost too much around 350-450
Oct 06, 2008 | JVC AV-48WP74 48" Rear Projection...
Convergance
the regulator will sometimes blow the fuse when it shorts. Hopefully the regulator will solve the problem if not you will need to trouble shoot the convergence board itself
May 08, 2008 | GE 46GW947 46" Rear Projection Television
GE 46GW947 BOWED PIC
the manual is almost impossible to find. But that chassis usually only has 1 IC that powers the convergence. Usually a STK730-020 or simallar. post the number off the IC you see up front and I will cross reference it for you and post a link where you can get a replacement
Apr 22, 2008 | GE 46GW947 46" Rear Projection Television
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
RCA CONVERGENT PROBLOM
The convergence problem is likely to be in the convergence power supply which is located above and between the two boards which lie flat inside the chassis. The power supply has a chip on it which is a common problem (If it is not the transistor type then change the whole board.) part number on the chip where the metal heat sink is located. Part number may be STK 730-010 or STK 730-130 both number will work and must be unsoldered and new soldered in.
Jan 02, 2008 | RCA P52937 52" Rear Projection Television
GE 46GW947 46" Rear Projection Television Logo
95 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
