Question about SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive
USB drive shows incorrect size
My usb is 1 GB but shows 8MB when connected. tried different computers but same issue. on XP when i try to access through my computer. the USB says about doing a format.
in computer management it appears as 8MB in size. the USB belongs to my friend but i do'nt know the exact model and make
  • glibert Apr 23, 2008
    Not quite the same drive but same problem with freebie issued by the Economist. Sent it back. I have heard that certain drives from you know where are filled with unwanted stuff. And to add insult unformattable. I would take steps to get it changed.
    President:
  • 1,812 Answers
If your pc infected with the strong virus ,you can not find the hidden file ,
So it will be better to format your usb in another pc which is not infected ,
Please fol,low all the bellow step how can you mark a pc for infected with virus.
Follow the bellow link ,you can get a solution from.
http://www.fixya.com/support/t7700913-usb_not_formating
If you want to remove,virus can remove in different way,please follow bellow link.
First try to restore ,
There are two way to restore the system for your OS.
  1. Start PC
  2. Hold down or press the F8 key frequently.
  3. Soon a text mode windows will appear.
  4. Select SAVE mode using down arrow key.
  5. Enter
  6. Select your OS
  7. Enter again
  8. Wait
  9. Again an windows will open
  10. There will be two option YES /NO
  11. You will click on NO
  12. Now you can restore your OS
  13. Follow this links with pic
  14. Now you should select previous date
  15. http://support.microsoft.com/kb/306084
  16. OR http://bertk.mvps.org/
  17. Or http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
  18. Hope it will help you
  19. .
If the same problem do another,
http://www.fixya.com/support/t7665080-dell_inspiron_1501s_card
Hope this helps,
Posted on Nov 02, 2011
I have a problem with Hitachi 120 GB harddrive model E5K160. I tried to connect my HDD to several systems including XP and Windows 7 and I get the alert baloon that it got malfunctioned. USB device name...
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem
hope this helps
Jul 18, 2011 | Hitachi Hard Disk Travelstar E5k160 120gb...
My LaCie 500 GB external HD is not recognized by my (or any other) computer when connected, attempts to instal driver software fail and the device does not appear in the list of devices with removable...
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Dec 31, 2010 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
My Beyond Macro External hard drive model no BMMDU2 has stopped working.. It shows up in list of "Safely remove Hardware" but windows XP professional SP3 is not assigning any letter to...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Why won't the computer read the hard drive
* the USB cable
* the power-adapter
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Dec 17, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
When i connect the USB of my 500 GB passport WD it takes a long time to be identified by the windows, after this when i double click to open, it takes a long time to respond and nothing happens, sometimes...
Try using a different USB cable. Try a different USB port of that computer. If you have another computer, try using it with this hard drive.
It kinda sounds like it may be that USB hard drive too, getting flaky (going bad).
Trying different cable, USB port and another computer should help aid in debugging this. If it works with different items (cable, different USB port or computer) then you know it's your computer causing issues or it's operating system. If it's all the same outcome with different items tried then it's the hard drive causing issues. Not much to do but get another drive.
It should not matter if your computer's BIOS is set up for USB 1 or 2 support. The drive should still be seen with all files/folders in it, without slowdown or issues you've described.
Dec 04, 2010 | Western Digital Passport WDXML800UE...
Computer won't recongize my Maxtor one touch
If plugged in the first time, the external drive needs to be initialized from your computer. Here are the steps.
1. Plug in your external drive to your computer's usb port.
2. Right click your My Computer and choose Manage.
3. Click on the Disk Management from the left. The list of available drives will show on the right.
4. Right click on your External drive and select create partition (primary partition).
5. After that you now you need to format the hard drive. Choose quick format.
6. Right click again on the partition you've just created, now select "Format" and select NTFS.
7. Click Ok and follow the wizard as it will guide you until it is finished.
Hope this helps.
Nov 18, 2009 | Maxtor 160 GIGABYTE USB2.0 EXTERNAL...
Western Digital External USB 2.0 Drive sometimes won't connect
problems like these are usually because of the usb connections, if the usb connection isnt strong enough i.e getting enough power,
try it on another pc if you can see if the problem persists
Sep 09, 2009 | Western Digital USB 2.0 External Enclosure...
Seagate free agent 1.5 terabyte will not stay connected to my computer When I connect my free agent to my computer (Asus laptop with Vista Home premium) all the folders show up and I can access files for...
Check the HDD on a different USB port. It there is still problem, try that with a different computer. If it still shows this issue, try changing the USB cable. If the issue persist, its your HDD.
Jun 06, 2017 | Seagate Free Agent Go Small 12 GB USB...
I require a driver for our Beyond micro external hard drive.
It looks as though there is no driver support for beyond micro although the specs state that the drive is plug and play. which means you just plug it in and windows sets it up. other than that there are no software or drivers for it.
best of luck.
hope this helped.
please remember to rate me.
Mar 02, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Windows XP not recognizing the hard drives
On the first drive that does sound DOA if you bought it new, is less than one year old and the warranty hasn?t been voided you should be able to get a refund from the manufacturer. Second drive, have you tried connecting the drive enclosure to another computer as a test? If it can?t read the drive data either I would suspect the enclosure electronics are faulty. Also have you tried the firewire interface yet? Semper Fi, are you active or former?
Apr 29, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive Logo
1,465 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
