Hi my Zanusi Aquacycle 1050 is extremley noisy on spin, has the bearings gone? is it worth fixing? cheers Ray
  • Anonymous Sep 23, 2008
    bearing appears to be gone in the drum is it worth getting replaced
  • 101 Answers
No is not cost effective. hop this information could help you.
Posted on Apr 23, 2008
When I engage the mower blades it makes a nasty noise, like a bad bearing. I checked the brakes, belts, etc and all is well. Any thoughts?
hi there mrswp211
check out the pulleys from the pto to the deck for noise - if rumbly / noisy replace them , if not
remove pto to deck belt ( make note of belt routing 1st ) then rotate blades and spindles by hand give a good spin you should hear if noisy , grab blades and try to move them fore/ aft to see have movement if they do and they are not smooth and quite spindle bearings are the problem
generally if unit is noisy only when deck engaged bearings will cause this
but make sure pulleys on the top of eack spindle good to and everything is tight
a badly slipping vee belt will make a squeeling noise and somtimes will make the unit shudder
you will have to remove deck to replace bearing(s) , from experience replace mandrell/ spindle assys do both at same time because if one has gone the other wont be far behind - both do same milage and work and quite often if replace bearings only they dont go back in tight .
cheers hope it helps
pauly46
May 29, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Kenmore oasis washer noisy when spinning
Hi, your probably right about the bearing its usually hard to tell untill they have compltely gone have you tried turning the drum by hand to see if it turns smoothly if it does then it could be the motor thats noisy both can be replaced but the drum bearing is a nighmare trust me you need pullers and its hard work.
So try turning the drum by hand and see if you can feel any roughness or catching this would tell you if the drum bearing has gone.
Let me know the outcome ok
May 01, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No spin & drum is very noisy during cycle ,like a jet engine
Sounds like the drum bearings have gone and the belts come off.
Im afraid this is an expensive repair and not a diy job.
Sorry to be the bearer of bad news.
thankyou for using Fixya.
Mar 15, 2009 | Washing Machines
My zanussi aquacycle 1100 is making a very heavy clonking noise on spin cycle.Have you any suggestions? Thanks Craig
Sounds like the main drum bearings have gone.
Turn the drum by hand and if it feels rough or noisy , the bearings have gone.
There should be little or no noise when you turn the drum by hand.
It is quite an involved repair , as it entails a complete strip down.
Plz rate my comments.
Tanks, and merry xmas.
Dec 20, 2008 | Washing Machines
Door
it probabbly broke somewhere.
if it is possible to take the handle out, I would investigate the problem further.
not worth fixing the handle, you may have to get a replacement.
Mar 16, 2008 | Washing Machines
The drum will not spin round
drum bearings are gone big job, may not be worth repairing.
Mar 01, 2008 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
