Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Mitsubishi DM board repair link no longer found...
I had previously book marked a page for your detailed link to the Mitsubishi DM board repair at this link - http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair and now that link is gone.
My friend has a Mitsubishi WD-82825 DLP that I was going to use your DM board repair link as a guide to determine if the capacitors were the problem with his TV. Is there anyway you can provide a new link to the location for those DM board repairs instructions? Thanks in advance for any assistance you can provide.
  • 1 more comment
  • blariz Apr 23, 2008
    CORRECTION: My friend has a WD-62825 TV rather than the typo WD-82825.
    If it would be easier for the instructions to be mailed to me directly, my email address is blariz at gmail dot com. As you know to change the at to @ and the dot to .
    Thanks.
  • strenz May 02, 2009
    I have a Mitsubishi WS-55813 with a bad DM Board. Can I fix or replace at a reasonable price?
    Thanks!
  • 1153 Answers
SOURCE: 2002 Mitsubishi VS-50111 WIll Not Stay on
FIRST Check for open fuses F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF fuses are open then convergence output circuit would be your problem.
Posted on Dec 17, 2007
  • 4 Answers
SOURCE: blinking green light
The DM has caps on it that are easily changed if you can solder, a google search should lead to many forums with the proper instructions
Posted on Dec 23, 2008
  • 668 Answers
SOURCE: No DM Board on WD-65833
The Main Board contains the DM circuitry. And you are right, this board does not fail in the way of its predecessors. What is the unit doing?
Posted on Jul 17, 2009
  • 668 Answers
SOURCE: WD-65833
The Main Board contains the DM circuitry and does not fail in the same way as it's predecessors. What is the unit doig?
  • 3 Answers
SOURCE: Mitsubishi Diamond blinking green light of death
try going to tvrepairworld.com located in NC. Inquire about their dm26 kit with cd!
Posted on Jan 26, 2010
5 year old mitsubishi wd-62525 with blinking timer light. This site says there aren't replacement boards available for it any more. Also to send it to a technician for repair. One suggestion was that it...
The WS62525 doesnt have an inverter board. The blinking led is usually caused by failed capacitors on the DM board. You can get the V26 Chassis dlp DM repair kit at the following link which contains the capacitors and the CD with detailed instructions. www.tvrepairworld.com
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Will not turn on-has a fast blinking green light
the DM board needs the capacitors replaced. You can get the V26 DM repair kit at the following link which will usually fix that issue. The kit contains the capacitors and the CD will detailed instructions.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green Light Under Timer Stays Flashing and Will Not Go Out
Mitsubishi has repaired some sets if you have the origional purcahes documents. If not you can get the v26 DLP DM repair kit which should take care of that issue. Heres a link to the kit if needed.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Apr 21, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi 65" model # ws-65511
The steady green blinking led is due to the DM not completeing the boot Cycle. You can get the repair kit at the following link which contains the replacement Capacitors and step by step detailed instructions so you can do the repair yourself. Very inexspensive Kit
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Mar 02, 2009 | Mitsubishi WS-65511 65" Rear Projection...
WS 55859 DM board needs repaired
Its not just the DM board that needs to be repaired. The power supply & the FMT board also. These are no longer available. Mitsubishi will rebuilt the entire chasis. You have to remove it & ship it to Georgia without any cut wires. You need to get authorization from parts department 1st.
tvdoctor
Feb 28, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Blink green light of death - mits ws55613
you can get the repair kit which contains the replacement capacitors and the CD which includes detailed photos that show and explain how to do the repair, and the cD even contains the full service manual with full schematics manual as a bonus. Heres the link to the proper DM kit for your model.your model is the V23 chassis.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v23-dm-repair-kit/cName/repair-kits
Jan 24, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 62825 flashing green light on timer set wont come on,try reset same problem ?
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor, T.O., Ca
Jan 19, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
Jun 03, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi flashing light replaced capasitors that were blown tv still has flashing light
The four cap replacement in DM module repair is simplistic
and incomplete, as you found out. ALL defective DM modules
have bad SMC's ( small "top hat" caps) AKA surface-mount
capacitors that can be changed only by the most highly skilled
bench techs. We used to change out hundreds years ago in
camcorder circuit board repair.DM board repair is a much more
accessible,thus more "do-able". For more info.............T.
Sep 26, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
433 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
