Have acanon mx 310 installed and operating,but cannot receive faxes
I called canon tech support. I had the phone lines plugged in incorrectly,the problem was fixed but i don't know exactly how i did it.Thanks anyway.
Posted on Apr 25, 2008
The canon 310 MX is not able to accept new ink cartridges error 6000
if you purchased a canon 310 mx and if it is new..contact the supplier about it.So that they can instruct you how to fix it..Good day
Dec 02, 2011 | Canon PIXMA MX310 All-In-One Printer
I just received a new sharp mx-m260 copier and now need the mx-mm9 fax function. How hard is it to install the fax function
which model do you have. you have listed two different models in you post mx2300 is color MX260 is b/w.
Anyway the mm9 is a memory module for fax not a fax kit. The fax kit is a Fxx7 I think
May 24, 2010 | Sharp MX-2300N Color Copier
The main tel line goes into 2way splitter one for high speed internet, the 2nd goes to mx 310 canon all in one , can send fax but i cant receive any , i tried my level best with out...
do you have a filter on the line? usually, you need a filter to keep the phone and data sides separate. Fax machines are generally treated as phone devices. If you are in the US, ask around, chances are somebody has a filter you can use, I know I've probably got half a dozen in a box somewhere from every time I've had dsl set up.
Feb 01, 2010 | Canon Office Equipment & Supplies
MX-310 has fax's in memeory but keeps printing the first page of the first fax only. Screen says check paper size. When i push ok it only will print the first page over and over. How do I change it?
If your Canon MX-310 has been set up to print faxes as they are received, then what is actually in memory is a "received fax report". If you select a particular fax in this report, it will print the first page of the fax to remind you of the content.
Your Canon MX-310 will store fax documents in memory if:
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Sending a fax directly from computer using Canon Pixma MX 310
With the document open, you click Print, then choose Cannon ...Fax.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Jan 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
Dec 02, 2008 | Canon MX300 Office All-In-One Printer
Fax machine cannot sed or receive faxes
tell me the model of your Fax Machine
Nov 11, 2008 | Office Equipment & Supplies
MX310 Canon
Is your call waiting on? take it off and see what happens.
Sep 17, 2008 | Canon PIXMA MX310 All-In-One Printer
Pixma mx 310 fax auto
enter rx settings and select teleline as fax priority.
Mar 30, 2008 | Canon FAX-JX200
21 people viewed this question
jasbo
jasbo
