Question about Black & Decker BDCH200 Ceramic Compact Heater
Black & Decker BDCH200C Ceramic Heater
My heater was working a couple of days ago, now it will only stay on for a few minutes before the caution light comes on. It is plugged in, the filter in clean, and it is sitting on a flat surface.
  • Anonymous Nov 14, 2008
    I bought two of these heaters and the same thing has happened and now they won't come on at all. bought these in August and now it is November and both heaters don't work...solution!!!!
There is a thermal fuse in this heater. A 133 deg. C fuse along with a bimetalic thermal cutout is attached to the top of the ceramic heater housing. This fuse is probably open, and is the most likely cause of your problem. This fuse is riveted in place, and is not easy to change.
Opening the heater case requires a special anti-tamper screwdriver. B&D don't want you inside this unit.
Posted on Nov 27, 2008
Use Torx T8 screw driver to get the special screws out and once inside find this thermal fuse and bypass it by soldering a piece of copper wire into each rivet. That thermal fuse is a safety feature that is a waste since there is a bi-metallic cutout that will trip the heater element out if the fan quits. Many small motors and appliances use these devices that fail and render the unit disposable and force you to buy a new one.
Posted on Dec 18, 2012
  • dragulaxx402
    dragulaxx402 Dec 18, 2012
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
Atwood 6 gal w/h won't stay lit longer than 12 minutes
After it is stored for the 2 weeks, do you turn water on to it, then bleed out any air through the taps before lighting it? If not try that and see what happens and let me know if any different.
Mar 14, 2010 | RTO Atwood Water Heater - 6 Gal LP
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Infra red heaters wont stay lit flame in the tubes
have you tried to heat up thermal couple for a couple of minutes. It takes a few minutes for the flames to actually starts heating thermal couple you might have to move thermal couple a little closer to heater flames
Jan 16, 2009 | Reddy HD30 Heater
Lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Feb 12, 2008 | Heating & Cooling
CAUTION LIGHT only -- no Fan or Heat
According to the manual, the "Caution Light" means that the unit has overheated. They suggest running on a lesser setting, but you also may want to see if you can return the unit (if it is still under warranty).
Mar 31, 2007 | Black & Decker BDCH100 Ceramic Compact...
Noisy B&D Ceramic Heater
unit uses a sealed "muffin" fan.  you could check out grainger supply for a replacement fan.
Feb 22, 2007 | Black & Decker BDCH100 Ceramic Compact...
Black & Decker BDCH200 Ceramic Compact Heater Logo
395 people viewed this question
Top Black & Decker Heating & Cooling Experts
paulcarew
Rob
Rob
John Aman
Are you a Black & Decker Heating and Cooling Expert? Answer questions, earn points and help others
