Question about HP Office Equipment & Supplies
HP6180 All in One. HP sent me an upgrade for the software and since it (automatically)tried to install (failed) the printer doesnt work and jobs are queued. The printer is on a wired network and the other PC prints fine (it wasn't 'upgraded' how do i fix this other than removing all the HP software and reloading?
  • 208 Answers
SOURCE: Print jobs are not getting queued.
This is late but most likely the IP address is set to DHCP or auto and the printer is changing the IP address.
You need to set it to manual, and set the IP address static.
Those machines will change the IP address by itself.
Sometime even when you have set it manually it will change back to auto.
Posted on Dec 04, 2007
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
SOURCE: HL-5250dn ona Bonjour network will not work with Leopard
Brother is totally fucked up under Leopard, found so far no chance to fix it.  Brother's own printer drivers are 10.4 only -- lame
Posted on May 10, 2008
gwbm
  • 353 Answers
SOURCE: Epson Stylus C88 puts the job in the queu and doesn't print
Have you tried running an independent printer check - see
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
If the printer prints the test page OK, it means the problem is with the computer. If it were a PC, I would uninstall, reboot and then re-install the driver software. Maybe this will work with a Mac?
Posted on Feb 22, 2009
SOURCE: Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Posted on Mar 26, 2009
Error 49.23F9
. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 19, 2014 | HP CP3525N Color LaserJet Printer
Tip
Solve Error:49.2f9d error of HP LaserJet Printer
49.XXXX is a critical firmware error. It may be caused by a bunch ofthings such as bad input data or data corruption due to poor cables.
From the service manual :-
Recommended action
1. Press CANCEL JOB to clear the print job fromthe printer memory.
2. Turn the printer off, and then turn the printeron again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430.
Click DownloadDrivers and Software.
Check for thelatest firmware image version at the bottom of the page.
If this firmwareimage is newer than the one installed on the printer and the printer canreceive a firmware update, download the newer firmware upgrade.
Not all printermodels can receive firmware upgrades.
4. Try printing a job from a different softwareprogram. If the job prints, go back to the first program and try printing adifferent file. If the message appears only with a certain software program orprint job, contact the software vendor for assistance.
Hope this helps
on Dec 29, 2010 | Office Equipment & Supplies
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
How solve error 49 on 4730mfp
it's a long one !
Dec 18, 2012 | HP LaserJet 4730mfp All-In-One Printer
Please give me any solution to stop 49 FF05 printer error
2. Turn the printer off, and then turn the printer on again.
3. Go to http:www.hp.com/
support/lj2420.
Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update, download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
Aug 30, 2011 | HP LaserJet 2420 Printer
How to solve service error 49.00 in hp laserjet 2430dtn printer
49.XXXXX ERROR
A critical firmware error has occurred.
1. Press Cancel Job to clear the print job from the printer memory.
www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
1. After performing the actions listed in the preceding item, if the message
persists when using different software programs and attempting specific print
jobs, disconnect all cables that connect the printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs and thirdparty solutions from the printer.
4. Remove all of the EIO devices from the printer.
5. Turn the printer on.
6. If the error message disappears, reinstall each DIMM, Compact Flash card, and EIO device one at a time, making sure to turn the printer off and then on again (booting to the Ready
prompt) as you install each device. To replace a DIMM, see Appendix D - Printer memory and expansion in the LaserJet 2400 Series User Guide.
7. Replace the DIMM or EIO device that caused the error message.
8. Remember to reconnect all of the cables that connect the printer to the
9. If the error message persists, reinstall the firmware with the latest possible firmware upgrade. Go to http:www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software.
10. Replace the formatter
Feb 28, 2011 | HP LaserJet 2430dtn Printer
Downloaded the software from HP for my PSC 1350 All-in-One, and it ran on my XP machine, got to 100% extracted, then the screen just went to my desktop..... No action..... No install wizard. No indication...
it is very possible that because you have another hp printer active with that computer, and the software from the new hp printer may be conflicting with the software already installed into that computer, and becuase of that, the computer automatically drops the new installation of the software from the new printer, just like it never happened, in almost any case, you will have to uninstall the whole software program from the other printer already installed into that computer, and install the new software into your computer, if that still doesnt work, then your new printers software, the new printer, or both are not compatable with your computer
Jan 21, 2011 | HP PSC 1350 All-In-One Thermal Printer
My printer hp lj 3005 in error code 49.2f9d please solve my problem
49.XXXX is a critical firmware error. It may be caused by a bunch of things such as bad input data or data corruption due to poor cables.
Recommended action
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update, download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
Hope this helps
Dec 29, 2010 | HP LaserJet P3005 Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
HP6180 Printer. I keep getting an error message, Ink cartridge em
some cartridges are charged up ( have a chip fitted to them )
If the chip is not charged to tell the printer it,s full of ink. this will cause the problem.
have you tried. unplugging the printer from the mains. then powering it back up.
also try using the printers own software to add new cartridges et,c.
you could also try re-installing the printers drivers/software if you have it,s instalation disk.
Mike @ Compurepair.
Jun 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
107 people viewed this question
Ben Johnson
