Question about Dishwashers
Door Interlock switch Maytag MDB4100 dishwasher
The Door Interlock switch for my Maytag MDB4100 dishwasher seems to be intermittently turning off the dishwasher during it's cycle. A simple push at the top center on the outside of the door reconnects the switch and it will run for anywhere from 2-seconds to 2 minutes or even through the rest of the cycle. How do I fix it to make a permanent connection?
  • Bob Stevens Apr 24, 2008
    Thanks, I'll try it. Bob
  • 145 Answers
If the door is not latching well enough try adjusting the spring on the tub it's the male part that goes into the door latch. If that doesn't help you need to replace the latch. It's inside the door. The switch is mounted to the latch in the door so to get to it you have to remove all the screws around the outside edge of the inner door panel. Unhook power before replaceing latch or switch!
Posted on Apr 23, 2008
My dishwasher does not allow me to enter any control inputs on the panel. 'i might be the interlock on the door switch, because it came on once. Does the door interlock disable all control panel...
I don't know about the door interlock, But I would unplug the power to the dishwasher or turn off the breaker to it......Some times the microprocessor gets locked up just like a computer By shuting the power off and turning it back On can reset it. It's worth a try I don't know if this will help but is what I would do if it was mine........
Feb 01, 2011 | Maytag 24 in. MDBH965AW Built-in...
We turn on the Dishwasher but no water coming into the dishwasher
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
The unit does not run at certain times. If you push on door or move a little it seems to start but seems to get worse. Any clues. Its like some times it turn right on, other times it won't. Thanks Mike
sounds as if the door switch is bad. this switch is activated when you close the door and lock it. The way the switch works is there is a protrouding peice of metal out of the dishwasher at the top where the latch secures. This metal pushes a lever inside the door itself. If you look at the door at the top where the latch is there is a small hole. If you were to take a small screwdriver and push that tab in at the hole the dishwasher will activate with the dorr open If it doesn't the switch is bad or if you have to wiggle the screwdriver to get the dishwasher to turn on the switch is bad. REMEMBER if the switch is pushed in and the dishwasher turns on the water will spray up at you so make sure you shut yhr door as much as possible and only activate the machine to test the switch. Once you pull the screwdriver out the machine will diengage. If the switch is bad remove the front panel of the door and you will see the swtch. Take the machines model and serial numbers to an appliance repair shop for replacement
Good luck on your repairs hope this helped\
Dave
Jan 12, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishwasher makes a grinding noise when you start it and when you open the door it appears as if the bottom arm is not spinning
if the motor is grinding and not washing the impeller may be broken or there is an obstruction you will have to remove the motor to check this if impeller faulty purchase new part and fit good luck
Nov 05, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Power not coming on
When a dishwasher appears to be dead, many times the door latch is to blame. On some models, that latch has a safety interlock switch directly controls the power, so that when the door is opened during a wash cycle, power is removed.
The problem is that the interlock switch can fail or get un-aligned, so the dishwasher does not get power.
Depending on your skill level, you can investigate the problem, using a phillips screw driver to open up the latch so you can see the interlock.
Good Luck!
Apr 27, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag MDB4100 Dishwasher - Water Does Not Drain From Tub
go to managemyhome.com and pull your manual up from there.
Dec 19, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
Door opens beyond position parellel to floor
Hi dougisommer
I'm Harvey the Master Plumber.
Your question is: The door springs seem fine but when we open the door and wheel out the lower dish rack, the door drops further and the rack rolls down to the floor. Reading other postings, it seems like a good name for this is a broken "door catcher." How can I fix this?
You may need a sevice tech for this. The 'door catchers' on the sides of the unit can only be accessed after removing. Not a job for the inexperienced.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
Dishwashers Logo
298 people viewed this question
Top Dishwashers Experts
