Question about Brother GX-6750 Typewriter
My GX-6750 How do I get my Daisy wheel installed correctly so that when I strike the J key, it prints a J (and not some other letter....)?
  • BMH247 May 18, 2008
    tHE DAISY WHEEL ON MY BROTHER GX-6750 IS OUT OF ALIGNMENT. iF I TYPE A "J" IT WILL PRINT AS A "m". HOW DO YOU ADJUST THE DAISY WHEEL??
    Problem Solver:
  • 4 Answers
The print whell may be rubbing on something....exp ribbon....check and make sure there is nothing blocking the free movement of the wheel.
Posted on May 01, 2008
3 Suggested Answers
  • 329 Answers
SOURCE: Brother GX-6750 Daisy Wheel
Install wheel, turn machine on and off this resets the printer and home timing. If it still does not correctly, adjustments needed..
Posted on Jun 12, 2008
  • 610 Answers
SOURCE: My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Posted on Nov 12, 2009
How do i change the font on my GX-6750 Typewriter
The Font or letter size is depends to your printing fonts or daisy wheel. Buy a different Font size of daisy wheel or printing wheel.
Jul 07, 2014 | Brother GX-6750 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
Gx-6750 typewriter problems
Check to see if the unit is not on the demonstration mode. Also, does this unit have language change feature? if so, maybe it is set for another language and you cannot of course recognize what is is printing. Or , has any liquied or hi level of moisture gotten to the unit o r the keyboard? The moisture will effect everyhting and make it iratic until thoroughly dry. Goodluck, Macgivor
Jan 02, 2010 | Brother GX-6750 Typewriter
Oct 26, 2009 | Brother ML-100 Typewriter
Brother GX-6750 Typewriter printing problem
have you tried chaging the daisy wheel with a known good one? If yes, have you checked to see if the hammer is in a good condition?
Jun 02, 2009 | Brother GX-6750 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Apr 23, 2008 | Brother GX-6750 Typewriter
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Cannot type letters.
Your T/W neads a new keyboard membrane, you cannot clean this type membrane so you will have to replace it.
May 26, 2007 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
219 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
