Question about Mitsubishi VS-45609 TV
Tv wont turn on
Tv turns on but the screen is black, the little green light, lights up. we have had in plugged in the surge protector.there also is no sound, when on.
Have you tried unplugging your set for ten minutes and plugging it back in? Sometimes this will reset it. Also try hiolding the menu and input buttons in at the same time to see if you can enter the self diagnosis function built into the set. You should notice the light blink a two digit code. If thats unsuccesful your probaly looking at some bad capacitors in the power suppies or regulators. How are your trouble shooting skills?
Another problem that may be causing this is repaired by doing the following:
Remove the VP plug and solder a 4.7 mfd 35/50 volt electrolytic capacitor between pins 5 and 11 of the VP connector with the pos lead to pin 5. Solder a .01 cap between pins 7 and 9. You might also want to check out www.FreeFlatScreens.com/default.aspx?referer=7509165 for an opportunity to earn a free replacement for this set with a little effort on your part.
Posted on May 09, 2008
I turned off my seike tv model number se321fb and now it wont turn back on? the surge protector has power how do i get it to come back on?
Even though the indicator light on your surge protector is on, the surge protector outlets may not be working. Test it by plugging in a different electronic to make sure it still works.
It could also be a problem with your remote, such as dead batteries or that the remote is no longer programmed with the correct codes.
Here are a couple of troubleshooting checklists that can help you identify the problem and what you can do to solve it:
Remote not working
No picture on TV
I hope this helps!
Aug 03, 2012 | RCA Televison & Video
TV quits working, screen goes black and red light next to power green light flashes 4 quick flashes . After a second or two of no flashing,red light repeats "code" flash. We pull the power plug at the TV,...
The Sony diagnostic routine for 4 blinks indicates it to be a vertical deflection problem.
Did you see a solid horizontal line in the center of the screen prior to it going out? If so, that is a tell tale sign for vertical problems.
basic sony reset below
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center
Nov 27, 2007 | Televison & Video
Sharp aquos 42 won't turn on even though the green light is on, turns on for a second then goes black, but green light is still on, if you turn off and on for about 20 times it eventually stays on
Call 877-332-7867 and allow the customer service representative to create a case file for you. Next ask to be walked through an INIT/factory reset. You will need two people unless your tv is plugged into a surge protector that can be switched on and off with your foot because the first step will be to unplug the television or switch off the surge protector it is connected to. The next step is to hold down two of the buttons on the panel while plugging the unit back in/switching tbe surge protector back on with your foot.
May 05, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Wd-62725 green light flashing continuously and TV will not Power
just happened to us, we unplugged in from the surge protector and plugged it in the regular wall outlet and were able to get the tv to come on, don't know why, but it worked
Apr 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
KP57WV600 SCREEN TURNS GREEN THEN BLANK
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
42" westinghouse flat screen wont turn on
Some surge protectors fail just when most needed.
Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
TV turn off itself and won't turn on
Sounds almost like you have a voltage missing on the power supply board. if its a missing voltage a service manual and a multi meter should help ya find whats missing But a shop repair on a set like this could cost a bit as anything over 27" is a little costoly to fix these days. Only way to see is call and say to your self How old is the set? is it the set you really like do you wanna spend 150 to 225 to repair? it up to you. Good Luck
Jun 03, 2006 | JVC AV-32FA44 32" TV
Mitsubishi VS-45609 TV Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
