Question about Childesigns Carrollton Crib
The sliding rail does not lock in the up position falls down when pressure applied. Does anyone know if there is a repair for this problem? Thanks. GML
  • 2 more comments
  • lalrita Jul 09, 2008
    I am having the same problem with the side rails not locking in place.
  • Alittia Oct 05, 2008
    I have this crib too, and the side rail falls off all of the time, I am really afriad my baby will get hurt. I have something under the rail holding it up for now. Does anyone know if this crib has been recalled?
  • afpatty Dec 09, 2008
    I have the same problem and I am pretty sure we're all screwed cause Childesigns went out of business in 2005
  • gulperi Apr 03, 2009
    I've the same problem. I turn the bottom locks upside down so now the crib rail doesn't move up or down. It stays put. Can be a headache trying to reach a baby when the mattress is at the lowest point but at least it is not moving.
    gulperi@verizon.net
I am also having this exact problem
Posted on Jul 14, 2008
Yep having this problem too, not very happy about it. I don't have a reciept or anything, but i really would like the company to provide a solution...and i am sure they won't just because i don't have my reciept
Posted on Nov 16, 2008
I have a TRE 50 stapler and can't remember how to load it.
look at the back of stapler if their is a tab push in and down than slide the unit out place staples on rail and slide the spring unit in and lock into position or if you have the jaw type one grab bottom of stapler push up and back separating the lock and open like a set of jaws the slide lock will slide back with spring place staples on rail and snap closed
Aug 24, 2016 | Office Equipment & Supplies
DFUD142 Dishwasher. Plastic clips holding Cutlery/Utensil Cradle sliding tray have broken. Looking for new clips or an alternative solution. Thanks
Hello, welcome to fixya
Here's what works for me, take the lower basket out and set it aside to give yourself a more work friendly environment. Now move the rack stops to the left if you haven't already and then the rack itself...example
and
Now you'll need to remove the bumpers at the back of the rack rail, example...
push down on the bumper as shown
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here individual holders # 8058638-77 from the link I pasted below at allvikingparts )
http://www.allvikingparts.com/Guide_Rail_Ball_Holder_p/pd110003.htm
The trick now is to install the balls into the holders first
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Thanks for visiting "fixya" today for your repair help and good luck. Let me know if you require further assistance.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Sep 13, 2011 | Viking DFUD142 Built-in Dishwasher
D1776 asko dishwasher upper basket ball bearing asssembly falling apart
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself.
i.e.
and
Now you'll need to remove the bumpers at the back of the rack rail...
i.e.
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here )
Thanks for visiting "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
May 16, 2011 | Asko D1776 Built-in Dishwasher
I have a ASKO 1796, I love it, but I need to change the right dishrack ball bearing cage. Would you explain to me how to put back the rail in the rail support. Sorry, for my english, it's not my mother...
Welcome to fixya
i.e.
and
i.e.
and pull it down and out at the same time...it takes some force as evident by my finger tip ha ha, you can use a small screwdriver...I'm just stubborn.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Jan 26, 2011 | Asko D1796FI Built-in Dishwasher
How do you replace the rail replacements in
Welcome to fixya.
i.e.
1d854c5.jpg and
i.e.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Oct 27, 2010 | Asko D1776 Stainless Steel Built-in...
Replace upper basket and bearings on Asko dishwasher 1805
Welcome to FixYa.
Yes the upper rack is pretty straight forward, but the bearings are tricky.
i.e.
1d854c5.jpg and
i.e.
The trick now is to install the balls into the holders first...
Thanks for visitng "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Sep 23, 2010 | Asko D1876 Dishwasher
Seat Position Cant be moved
The manual lever to release the seat is supposed to have a spring on it to return the release lever to the lock position, if the lever does not spring back when you let go of the seat adjustment lever then you know there is a missing, dis-connected, or broken return spring.
If this is the case try putting the seat where you want it to be and make sure that the adjustment lever returns to the lock position, now check to see if the seat will lock in with the adjustment lever in the lock position.
If it does lock in repair or replace the return spring.
Make sure that the adjustment lever is attached to the locking linkage and it does move the locking mechanism.
If it still does not lock into place then there is something wrong with the seat locking mechanism, and some WD-40 sprayed onto the seat rails and track might release a stuck mechanism, and if everything seems to be working alright, and you can see that the locking mechanism in the seat rail is moving in and out of the lock position, then the locking tabs are most likely sheered off and you will need to replace the seat.
Also look under the drivers side seat and compare the lever position and the linkage connections with the passenger side seat, and make sure that it is all operating like the drivers side seat.
Apr 28, 2010 | 2000 Renault Sportwagon
Makita LS1013 Sliding Compound Mitre saw will not lock at chosen positions/angles on the turnplate other than the standard stop points. Turning the handle will not lock the turnplate anymore, it used to,...
there is a stop underneath the base that should put pressure on the table to lock into any position. I would unplug tool and turn over gently and look at the condition of the threaded rod which pushes the stop and the bracket that holds it. The stop itself could be worn or the rod might not be putting enough pressure on it. Also look at the cam for the slide to make sure the tube is not stuck inside it from applying too much pressure on it. You can remove it and "squeeze shut some and then I would reverse it" If the black knob has come loose and the hex nut has backed off the rod might not be long enough to hold the stop. You can go to Makitatools.com and download a breakdown to see what I am talking about. Let me know if you need more help.
Mar 24, 2010 | Makita 10" Dual Bevel Sliding Compound...
Need to fix the frame of a Phil & Teds Sport
there is only one company that does repairs to pushchairs like phil n ted thats www.buggypitstop.co.uk
Feb 15, 2010 | Regal Lager Phil & Teds Sport Buggy Single...
Cant open or release battry latch[presario v 4000]
There is another little switch like slide near the side of the laptop towards the end of the battery compartment. This a lock for the battery latch. Slide the switch to unlocked position and then try releasing the battery again. When you put the battery back or a new battery in , be sure to slide the switch to the locked position. This is just an extra feature to make sure you're battery won't fall out. If this solved your problem PLEASE rate this as fixed. If not do not rate yet just add a comment letting me know what happened and I'll be glad to assist you further. Thanks and have a nice day.
May 02, 2008 | Computers & Internet
Childesigns Carrollton Crib Logo
265 people viewed this question
Top Childesigns Baby Gear Experts
Jaime Hernandez
john h
ray gallant
Are you a Childesigns Baby Gear Expert? Answer questions, earn points and help others
