How do I create more ports on the router - Computers & Internet
    Guru:
  • 1,342 Answers
You would need a switch or another router to create more ports.
Posted on Apr 23, 2008
Open tcp ports
http://support.linksys.com/en-us/support/routers/E3000
This should have a manual for this router that will explain how to open ports on the router for game play.
Jul 17, 2013 | Linksys E3000 Wireless Router
My NetGear Router will not let me video chat on xboxlive
Hi, You will have to open ports on the router for XBOX and for this you need to have a computer connected to the router.
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari)
2. Access the router, usually with http://192.168.0.1 or http://www.routerlogin.com.
3. Login to the router (Username = admin Password = Password unless you have changed it)
Create Services for the ports on the router:
1. Click on Services under Security.
2. Click on 'Add Custom Service' button.
3. Specify any name for the service (for example, XBOX1).
4. Specify the Start and the End Port as 88.
5. Click on 'Apply' button
6. Follow the steps 2 to 5 to create the services XBOX2 for the ports 3074.
Open Outbound rules for the services created using the steps below:
1. Click on 'Add' for outbound services.
2. Select the Service as the one that was created(like, XBOX1 in our case).
3. Select Action as Allow Always.
4. Set LAN users as Any and WAN users as Any
5. Set Log as Always and Click Apply
6. Follow the same steps for other services also.
Open Inbound rules for the services created using the steps below:
4. Set the 'Send to LAN Server' as IP address of the XBOX
5. Set WAN users as Any and Log Always
6. Click Apply. Follow the same steps for other services also.
Click Apply on Firewall Rules Page.
I hope this information allows you to resolve this issue.
Aug 21, 2009 | NetGear DG834PN Router (DG834PNAU)
How to create a port on my router
please follow the steps are given below,
1.Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
2.Type your username & password and login to device.
3.A web page will appear , you can go to security section & select virtual servers.
4.From virtual servers section you can create port you want either TCP or UDP.
best regards,
Krishan
May 09, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Port setting to allow my xbox to run games
Hello djand2kidz,
Inorder to resolve this we need to open application ports for the Xboxconnection. This problem can be resolve by any of the following:
  1. Opening port Numbers TCP 88, TCP/UDP 3074
  2. Lowering MTU size and Disabling SPI
  3. Enabling UPnP
  4. Enabling DMZ
  5. Upgrading the firmware of the router.
  6. Set NAT filtering to open (Only available on WGR614v6, v7, and v8)
Here are theoptions on how your Xbox connected to the internet. Opening Port Numbers TCP 88, TCP/UDP 3074:
1. Make sure that Xbox has valid IPaddress of the same range of the Netgear router.
2.
Assign static IP address on Xbox.The following values should be used while assigning static IP address on theXbox.
IP Address: 192.168.1.x (e.g. 192.168.1.200)
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
Note: Here ‘x’ can be any uniquenumber from 2 to 254 depending upon the IP address assigned to remainingcomputers in your network.
3. Oncestatic IP address is assigned, the requisite port numbers can be open using thesteps below.
a. Open the browser(Internet Explorer or Netscape) and type the IP address of the Router(192.168.1.1) in the address bar.
b. It will prompt youto Login into the Router (Username = “admin” & Password = “password”).
c. Select "Port Forwarding" under "Advance"
d. Select "Port Forwading" under "Service Type"
e. Click on "Add Custom Service"
f. Prepare the following Service for opening port 88 TCP/UDP.
g. Clcik on "APPLY" after creating Xbox_1
h. Again click on ‘Add Custom service and thenenter the values to open port number TCP/UDP 3074.
i. Click on ‘Apply’ after creating Service Xbox_2.
j. OnceXbox_1 and Xbox_2 services are created you will there entries under ‘PortForwarding/Port Triggering Option.
Mar 29, 2009 | NetGear WGR614 Wireless Router
Forwarding ports on my router
I'm really not sure if opening those port will increase your internet connection, because if you have a slow connection you better check it from your ISP. You only need to open port if you're having problem with some application like servers and games.
But you really want to try to opening that port check this link how to do it, this is a sample on how to open port on your router. http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
May 10, 2008 | Belkin (F5D7230-4) Router (587009)
Cant get online?
  1. Turn off your PS2 console.
  2. Get your CAT5 Cable (link varies based on where your router or modem is).
  3. Put one end of the cable into the port of the Network adapter (or slim PS2 and PSX) port labeled "Network".
  4. Connect the other end in a free port in your router (or on the port on your broadband modem).
  5. Turn on PS2.
  6. Turn on modem (or router).
  7. Put in online game.
  8. Go to the online section in the game.
  9. Create a network Configuration
  10. Load it
  11. Create an ID.
Jan 07, 2008 | Sony PlayStation 2 (PS2) Console
How To Make a DMZ
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described in How is Port Forwarding Configured? However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RO318 Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 (MR314NA) Wireless Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 802.11b
How To Make a DMZ?
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding. However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RP114 Router
Computers & Internet Logo
18 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
