Question about Palm Tungsten E2 Handheld
Won't turn on I press the power button
The E2 was working just fine yesterday, and then later in the afternoon it would not turn on. I pressed all the buttons, sometimes twice to three times in hope a miracle would occur, and nothing happened. I also set it up to charge last night, but did not hear my usual "beep!" when I put in the little charge plug (and yes, the charger was plugged in). This morning it still does not want to turn on. Thanks for any help.
  • 5 more comments
  • gina valencia Apr 27, 2008
    my palm pilot was working fine and all of a sudden when i turn it on the screen is totally black; no power out.
  • bonniegustav May 03, 2008
    T 5, I my palm will not turn off, it desplays the PalmPower sign only. I have replaced the battery hoping that this was the problem, still an issue. Whe I reset the palm, I do not hear the tones when it starts up. If I hold down the on off switch it desplays to reset push the up button. I do not know what the "up button" is I have tried all the buttons. Any direction is welcome. BJG
  • NancyJBM May 22, 2008
    E2 suddenly dead, unresponsive to buttons or screen taps. Fully charged. Soft reset several times, no response. Weird part is that removing the SD card and reinserting it does produce a sound, nothing else.
  • madasme Jun 05, 2008
    My PDA was on and I was looking through my calendar when it shut off and will not re-turn on. I pressed the power button several times.... it appears dead... no response. I am afraid to push the reset button as I fear it will wipe out my data. I use it frequently and feel bare without it. Any info is appreciated. I will keep messing with it.
  • 0415 Jun 05, 2008
    Bought a new E2 and had trouble turning it on. Sometimes it would turn on, sometimes not. Now it won't turn on at all. I tried pushing in the on/off button while pushing the reset button at the same time. No luck.
  • Alease896 Jun 06, 2008
    Tungsten E2 will not pwer on. I tried soft reset, hard reset and still nothing. The normal beep that I hear when I connect the charger is missing... Called Palm support and they want $149.00 for service... This is very unfair that they do not stand behind their product. I feel lost without my palm..
    I NEED HELP!!!!!!
  • Anonymous May 18, 2009
    Tungsten E2 will not pwer on. I reset it but, still nothing. The normal beep that I hear when I connect the charger is missing. I feel lost without my palm.
Press the reset button on the back of the unit with the stylus tip.
Posted on Apr 27, 2008
There is a replacement battery that can be found on ebay for the Tungstern E2. I'm told like any re-chargable battery this one gives out too...
Posted on Jun 07, 2008
Won't Boot after pressing the power buttton
Unplug the tower and press power button for 60 seconds, if this fails the motherboard should be suspect, check all plugin connections to the motherboard especially power supply connectors.
Jun 17, 2012 | Dell XPS 8300 Desktop
Shutter clicks ever time I press a button & it won't take pictures
I had this problem this afternoon, and it resolved itself when I took the memory card out. It's been fine so far, all working as normal again! :)
Apr 16, 2012 | Pentax Kr Digital Camera
Storm knocked power off late yesterday afternoon....back on this morning. PC won't power up....small green light on back flashing. Modem, router, etc. all back up and running, but PC won't turn...
The first thing to try is to cycle the power. To do this, unplug the power cord from the back of the PC and press and hold down the power button on the PC for 5 seconds. This will completely drain any "stuck" power in the components. Now plug the power back into the PC and try booting. If it still does not come back on after this, then you may be dealing with a blown power supply. You can buy replacement power supplies from your local PC shop for about $50 for a 400watt.
To protect your devices in the future, make sure you have a good surge protector and / or a UPS (uninterrupted power supply).
Regards, Chris
May 25, 2011 | HP Pavilion a350n PC Desktop
HP media Center m7060 will not turn on
yur sys has a primary prob... the start button wiring or solderin myt ve gone chec it,..
Jul 30, 2009 | HP Media Center m7060n PC Desktop
Tungsten E2 wont power on
Turn it on pressing the reset at the same time or take out battery and unplug/plug the battery. Your battery may have died. If this is helpful, post as such. If it is a fixya, post as such. I had an E2, can tell you alot about it. TY
Jan 23, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Urgent response needed
1 press and hold the power button
2 while holding the power button, use the stylus to press the rest button on the back
3 wait for the "palm powered" logo to appear and then release the power button
4 when you see the warning message
either press "UP" on the 5 way navigator to reset
or
press any other button to do a soft reset
Best of luck
Jun 10, 2008 | Palm Tungsten E2 Handheld
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Palm Tungsten E2 Handheld Logo
163 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
