I couldn't open Epsom Printer Utility to find out which ink cartridges to replace. I tried a number of times to reinstall Epson Styllus C42 series. Each time only Epson series C88 appeared and I still couldn't open Epson Printer Utility. I tried again to reinstall. This time the Epsom printer Utility icon did dot appear.Instead a file icon appeared which said Epson plug-in and when I clicked on this the message said I needed to select an application. I was not successful is doing this either. I have a Mac OS X
  • 655 Answers
  • make a complete un-install
  • shutdown your pc.
  • Remove aal connection of printer from your computer.
  • Then restart your pc.
  • Run setup and don't make connection untill setup fineshes or setup said to make connection.
Think it will fixed..
Good Luck
Iqbal
Posted on Apr 23, 2008
    Sergeant:
    Champion:
  • 298 Answers
It is possibility you have wrong ink cartridge or
Wrong software installed.Check your manual
to see if you have the right cartridge (original Epsom)
Also if your drivers are for a Mac,and not for a PC
    Sergeant:
    Champion:
  • 306 Answers
You completely uninstalled the software then reinstalled the software???
  • cory casper
    cory casper Apr 27, 2008
    make a complete un-install,
    shutdown your pc. ,
    Remove aal connection of printer from your computer.,
    Then restart your pc. ,
Change cartridge before its finished on epson stylus sx100
  1. Do one of the following:
    • Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Then click the Maintenance tab.
    • Macintosh: Open the Applications folder, open the EPSON Printer Utility 2, select CX7400 Series, and click OK
  2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
Sep 08, 2014 | Epson Stylus Office Equipment & Supplies
sure...let's check for o/x compatibility first..I'll check the epson site.
as to the credit, I believe there are options for that in the sign up screen if I am not mistaken
Apr 26, 2008 | Epson Stylus C42+ InkJet Printer
Replacing ink on an epsom wf7010 with generic ink
Try Genuine Epson cartridges and if the white strips disappear then you know it's the generic carts. If not then clean the printer heads, if that doesn't do it then get a new printer.
Feb 10, 2014 | Epson Office Equipment & Supplies
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access...
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
Unable to install black ink cartridge on my Epsom Styus nx110 printer. Help Cartridge think cassette won't stop where I can install the toner, just goes back to the right. It is tax time, you know.
You can always do it thru the utility.
click on start, click on printer n faxes
You will see your epson icon with a check mark, double click on that icon, click on printer tab, then slect printing preferences, printing preferences utility will come up. click on tab, Click on the Maintenance Tab as shown below, then select ink replacement icon. Follow thru to changing cartridges. It will move the ink station to the proper stop.
If you find this helpful pls rate me.
Thanks and Good Luck.
Feb 03, 2010 | Epson Stylus D92 InkJet Photo Printer
How to change ink cartridge in epsonnx110
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
Full ink pads on Epsom styllus C43SX Printer
Google or call tech support for instructions. Go to the website below and get a Waste Ink Container kit and a CISS while you're at it. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 20, 2009 | Epson Stylus C43SX InkJet Printer
Printer will print with almost no ink on page in colour or b/w
You have to have both the cartridge installed and then
Run a nozzle check to make sure the nozzles are clean. Try running a printer self-test to make sure the printer is running properly without using the computer.
Macintosh 9.x or earlier: Open the File menu and choose Print. Click the Ink icon. You'll see a window showing the ink remaining in each cartridge.
Macintosh OS X: Double-click the Applications folder on your hard drive. Double-click EPSON Printer Utility, select the C42 Series printer in the Printer List window and click OK. Then click the EPSON StatusMonitor button. You'll see a window showing the ink remaining in each cartridge
May 04, 2009 | Epson Stylus C42UX InkJet Printer
Resetting ink counters on epson c42ux
You can try the other software you can use to reset the counter.
http://www.coldreset.com/modules.php?name=News&file=article&sid=95
Also make sure that on the ssc software, you have selected the correct printer model.
http://www.ianwillis.co.uk/c42/
Mar 24, 2008 | Epson Stylus C42UX InkJet Printer
Epson CS3200 - Non-specific power-up failure & error message
From reading posts in the ssclg website mentioned above it seems Epson set counters that ensure your printer stops working after a certain number of copies so they can "service" it (or get you to replace it). When you download the utility mentioned above, read the help file. (Right click the icon in the tray to get it up.) It will tell you which buttons to press when, so that the counters are reset, and hey presto - your printer will be working just fine again.Search for your printer model number on the ssclg website to read others' similar experiences. I'm betting that, just like the rest of us, your printer doesn't actually have a problem at all.After pressing 3 buttons, mine is fne gain.
Jan 05, 2007 | Epson Stylus CX3200 All-In-One InkJet...
91 people viewed this question
jasbo
jasbo
