Creative Labs Zen Vision Digital Media Player Logo
Posted on Apr 23, 2008
Creative Zen Doesn't Recognize Music
I can add music to my zen using wmp 10 it says all transfers are complete and when I unplug it it says the library is rebuilding and it finishes and when I go to the library there is no music. Help?
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Aug 22, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
2454
Points
9
Turn off your player. Push in the reset and turn it on. You should get the reboot menu. Click on CLEAN. If it doesn't work, then REFORMAT after backing up your data. You can also reget the firmware from Zen website.
3helpful
When it the zen is turned on it says firmware
Had the same problem and nearly went nuts trying to fix it. Here's what I did:
1. Uninstall all creative driver & creative software.
2. Uninstalled Windows Media Player 11 (Rolled back to WMP 10) and restarted PC.
3. Uninstalled Windows Media Player 11 Runtime and restarted PC.
4. Downloaded and Installed the latest free version of Winamp from http://www.winamp.com
5. Connected my A/C Power Cord to my Nomad Jukebox then connected my Nomad Jukebox via USB cable to the Computer.
The computer should then recognize the Nomad Jukebox as "Found New Hardware" then "MTP Device" and lastly "Your new hardware is installed and ready to use.
6. If you haven't already, go to the creative website and download the Creative Zen Xtra PlaysForSure Firmware 2.10.03 and save it to your computer.
7. Run the Firmware (Make sure Nomad Jukebox is connected) and at this point the Computer should recognize the Nomad Jukebox and begin the upgrade.
After your upgrade is complete, You can go ahead and re-download Windows Media Player 11 and it will recognize the Nomad Jukebox.Not sure what version of windows you have, but I have two computers, one with windows xp and the other has windows 7 and Im able to transfer music perfectly fine with Windows Media Player and RealPlayer on both computers. I hope this works for you. Good Luck!
1helpful
I plugged in my creative zen mozaic to transfer
You can use creative centrale, but I personally wouldn't suggest it. It is overcomplicated. Whenever I transfer music I usually just use Sync on Windows Media Player.
My creative software for Zen Sleek Photo won't load on Vista
Vista by default will support the Zen Sleek Photo as an MTP device, which means that Windows Media Player will recognize it as well as Explorer.
You can use WMP to sync music to it, and Explorer to drag/drop photos to it.
I have a Creative Zen V 1gb, when I put songs on it with Windows Media Player, and unplug it afterwards, and when i want to start listening the songs on my MP3, it doesnt show any tracks! while WMP says...
Try updating your firmware, because "default" firmwares have problems sometimes with WMP Sync features that also adds a DRM code to each transfered track.
If not, make sure you use standard .mp3 extensions for your songs, because on basic settings WMP converts your audio files to .wma when you transfer it to an mp3 player
1helpful
Transfrering mucisc CD to ZEN via windows XP
It should use the same software to transfer music, but you may need to update the software to handle the new players firmware. If you are trying to use the old software from the old Zen, it may have some issues with the new player. The software for the newer Zen players is a bit different than older versions.
Does it give you problems ripping CDs or is it not transferring the tracks?
You may want to use Windows Media Player or another software to rip the CDs into mp3 format (I recommend that over other formats because WMA and mp4 are really hardcore with licensing and copying files to other computers.) and then transfer them using the Creative software or another media manager like WMP or Notmad Explorer or one of the many others out there.
If you have any other questions, let me know. I have worked with Creative players a lot over the years.
Cheers
47helpful
7answers
Instruction for zen mosaic by creative
I think alot of people are having the same problem I was. We got home, opened the box, plugged it in the computer, and nothing useful happened so then we installed the mini-cd. Well the thing is windows stops looking for a driver once it searches and finds nothing, and unfortunately those of us using XP do not automatically have the drivers. So...
SOLUTION
-If you have not already installed the mini-cd, do so, or download from Creative's site in the support section(if you do you might want to grab the latest firmware update)
-Once pack has been installed the drivers have been as well, BUT as I mentioned we now have to tell windows to look for them again.
-Reconnect your Mosaic
-Right click "My Computer"
-Chose "Properties"
-Click the "Hardware" tab
-Click "Device Manager"
-A window will pop up and you will see a long list with (hopefully only) one thing under the "Other Devices" sublist. It should be something along the lines of "Creative Zen Mosaic". Right click it
-Chose "Update Drivers"
-Follow prompts agreeing to search and auto install
-Once install is done, in a moment the screen on your Mosaic will say "Docked"
-Congratulations!
If you have downloaded the updated firmware this is the time to install:
-Ensure your Mosaic is in "Docked" mode
-Execute the firmware update
-Click "Upgrade"
-Wait (it takes a moment or two)
-Updater will say it is complete
-Mosaic will reboot
-Click "Close"
-Congratulations!
Hope that helps.
I just buy creative zen stone 1gb
Hey Sheikhea!
You won't need to download or install any programs if you have Windows Media Player on your computer. You can use other programs but WMP is probably the easiest!
  1. Plug in your MP3 player using the USB cord (should be in box)
  2. Open WMP
  3. (If your songs are already in Library skip this step). Click "File" (top left hand corner) then "Add to Library..." Click "OK" WMP will now find all music on your computer and add it to Library.
  4. If the internet is connected WMP will attempt to find song info such as title, artist, album etc. Otherwise right click on song and click "Edit"
  5. Click on "Sync" tab (top of player). A sidebar should appear with "Creative zen.. etc" written on the top.
  6. Drag songs into sidebar.
  7. Click "Start Sync"
  8. The songs will now download onto your MP3 player.
To organise your files into folders etc. go to "My Computer" then "Creative Zen etc" then "Music" and create folders (right click "create folder") copy, paste, and drag your songs in folders as you like.
You can now unplug you MP3 player and turn it on!
Please reply so I can know if this information was helpful or not and can help you further.
Happy MP3ing!
From Kat
C cover art does not transfer to my zen vision m, only the music tracks transfer
A few possibilities. Go to http://193.95.171.83/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=224,E=0000000000373151655,K=1742,Sxi=15,Case=obj(8179),Kb=ww_english_add,VARSET=ws:http://us.creative.com/
for more details
Creative ZEN players do not currently support album art from Rhapsody version 4.0.
Album art is either embedded in a track, or exists as a thumbnail image in a separate file, allowing one album art file to be associated with an album. Currently, Rhapsody only supports album art embedded in the track. Future versions of Rhapsody are expected to support thumbnail versions.
Creative Media Explorer or Windows Media Player 10 or 11 can be used to transfer music purchased from Rhapsody to a player with album art included.
Album Art is supported by Creative ZEN, Creative ZEN V Plus, ZEN V, Vision:M and ZEN Vision players.
The ZEN Vision (PF1150) requires a firmware update for Album Art. You can download the updated firmware:
If you experience any difficulty transferring Album Art with Windows Media Player 10 or 11, to ZEN Vision:M, delete WMPInfo.xml (see below), and then transfer the tracks again.
-Tha Mp3 Doctor
1helpful
3answers
Zen Touch mp3 player isn't able to play tracks in windows media player 11
im not sure but i think you have to create the playlist first then transfer to mp3
5answers
Confused!!!!
there might still be hope. If you downloaded firmware version 2.11.01 it will not be recognized by creative organizer; you will need to install plugins to make creative organizer recognize it again. Go to www.creative.com/support --> downloads and follow the links to download the plugins. There are 1 or 2 to download. Do you have windows media player 10? If so then the zen should be recognized in wmp 10 and you can download songs that way. If you have windows media player 11, you will need to roll back to windows media player 10 for it to be recognized. NOTE: if you don't use windows media player to sync songs, then just ignore everything I said about it.
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
