How to set up vcr tv receiver?
How do I set up reciever to tv and vcr, so I can record. I have it set up now, but it wont record. In order to watch vcr i have to switch to tv video but it will not record.
from single girl who never had to this set up before
  • habachi saleh Aug 18, 2008
    I dont know how to record from a tv. set connected with a receiver
    i don't know how to record from tv. set which is connected with a receiver
  • 979 Answers
The chain of signal that Must be followed is thus; Your satellite/antenna/cable must first go to the VCR, then the TV, Then the receiver, (The last connection is optional if the receiver has the coax on the back)..Hope this helps!...accordianman
Posted on Apr 26, 2008
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hy does a colored tv record in black and white on
I suspect that you have the video standard is incorrect. Ensure you are recording in the same format as the signal you recieve. IE: NTSC or PAL. Whatever but they should both be the same. IE: Signal recieved = NTSC Video recorder must be set NTSC as well. Same goes for PAL.
Jan 13, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
My zenith vcr recorder is recording blank but not my tv show and I don't know why. I have it plugged in to my tv - I have cox cable and a tivo box. My cable box runs ino my tivo and then to my tv. My vcr...
It seems to me that you have only got one set of RCA Cablec between the TV and VCR ( from VCR Video out to TV Video In), as such the VCR only works in playback mode, you need a second set of RCA cables (from TV Video Out to VCR Video In) then select the appropriate input (Video) for the VCR. make sure to follow the colour coding on the RCA plug / socket arrangement
Jun 18, 2009 | Zenith VR4206HF VHS VCR
I have a/v connections on my tv. In order to
hook up your tv output to your vcr in put or if you have a cable jack you can hook your cable to your vcr input and the out to your tv you will either have to change the channel to3 or4 or change the tv video input
Mar 01, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Oct 14, 2008 | GoVideo DVR4300 DVD Player/VCR
Record tv
The VCR will have to be on channel 60 as well in order to record a program. Hope this helps....accordianman
Apr 25, 2008 | Quasar VHQ400 VHS VCR
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
