The on-off/door lock LED flashesw rapidaly aty the same time as the easy iron and the delay time LED. Washer fails to start properly.
  • Anonymous Jul 30, 2008
    yes i have the same prob flashing door light and then the word door in led did you get it mended any help appreciate
  • 101 Answers
The door lock unit is bad , replace it.
Posted on Apr 23, 2008
The On-Off door lock LED flashes rapidly at the same time with Delay, Timer and Rapid LED. and it wont start.
Many times faults like this can be cured by Uplugging the washer from the mains power supply and leaving for 10mins. Also check all filters, drain and supply lines are clear and not kinked.
May 04, 2011 | Ariston Technologies AW129NA 16 Lbs Front...
What does a code f22 mean on my front load washer 9400
HI. This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Wich will be the actual CCU, if the wiring harness is ok, and connected properly)
Dec 30, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Delay start light is flashing and door will not
It is your control board that has failed. It is time for a new machine. It is a common problem. If it's under warranty get it fixed but the machine is starting to wear out.
Unplug and wait for a clicking sound this will be the electronic door lock releasing.
Dec 12, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Door wont lock
I solved my own problem...
The machine stopped due to either a heavy load or clogged drain. I cleaned the drain (by taking pannel off the front of the machine). Then, the machine wouldn't cycle and it said "door locked" but the door wasn't locked. Basically, you have to let the machine finish a complete cycle (whether or not it actually does anything). Every time the start/pause button flashes, push it to have the machine try to start. This will eat away at the time. Eventually it will finish the cycle and say 0:00. Now it should run. This can take up to 2 hours so be patient!
Mar 28, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
