Question about GE Dryers
My dryer (model #DBVH512GF1WW)periodically makes a rythmic knocking sound as the drum turns when drying clothes. We had one repair person out to look at it but could not find anything wrong with it. He said that maybe the heat expands the drum during cold weather and creates the knock. It happened again on Monday. The outside temp was well into the 60's. What might couse this "loud" sound? One other comment is the front lower left corner below the front load door gets extremely hot during drying. Is this normal?
4 Suggested Answers
  • 1122 Answers
SOURCE: kenmore dryer is making a loud knocking sound but
ONE OF THE DRUM OR BOTH ROLLER WHEELS IS BAD-MIKE
Posted on Jul 19, 2009
heatman101
  • 43501 Answers
SOURCE: MY DRYER HAS STARTED TO HAVE A KNOCKING SOUND ON
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Jan 15, 2011
  • 2468 Answers
SOURCE: DJXR433EC2WW Model GE Dryer Dryer makes
probably just the metal expanding as it gets hot or possibly a vane inside the drum gets loose after warming up,as for the over- heat issue,you probably need to dis-assemble the unit and clean out the lint from the exhaust piping from the blower to the outside venting exhaust,if theres a lot of lint inside the unit,you may also need to remove the drum and cleanout the lint by the heating element,this is easily done,by removing the top and front covers.then remove the drum belt,and remove the ground strap off the back outside of the unit,then remove the "E" clip thats there,then pull the drum forward toward the front opening to completely remove and carefully vacuum out all the unit because now you can access the motor also
Posted on Feb 14, 2011
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
The electric dryer will heat up to dry the clothes but it has a high pitch noise when you start it and periodically during the drying time it will make that sound. At first I thought it was the belt but...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 25, 2011 | Maytag Dryers
Dryer tub makes noise as it turns. 2000 model kitchenaid clothes dryer. noise occurs while drying. thumping sound.
heatman101
Aug 01, 2011 | KitchenAid Dryers
Tturn on dryer,clothes do dry,,but dryer makes loub knocking noise
drum rollers/glides, idler pulley, belt, or motor. here are two websites first rollers/glide, second the idler pulley, belt and motor. Good Luck Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 06, 2011 | Dryers
Dryer is making a"knocking" sound
drum rollers/glides:
Dec 25, 2010 | Dryers
Dryer is making a loud roaring noise. Drum still is turning and clothes dried. But noise is getting louder.
heatman101
Dec 14, 2010 | Kenmore Dryers
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
heatman101
Oct 02, 2010 | Maytag Dryers
Drum making intermittent sqeaky noise for 3-4 minutes then stops
heatman101
ytg
Jun 03, 2009 | Frigidaire Electric Dryer
Rythmic thumping sound
probably the rear bearing or the drum shaft
Nov 15, 2008 | Asko T701 Electric Dryer
Dryers Logo
159 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
