Broken part tat feeds paper through repair center locations gainesville fl 32653
  • Stanley1 May 14, 2008
    the small pastic part that rises the paper feeder (on the right hand side)when the drawer is open has broken off. any ideas who coud repair it?
Paper will not advance. i have uninstalled and reinstalled but problem continues
Posted on May 05, 2008
The door to the area where you open for a paper jam has broken away from the springs.
Unless this is a high end printer the best thing to do is just replace it and good riddance. As far as locations go check the Yellow pages for computer repair centers, staples is one, they can give you an estimate for any computer related device like printers and such.
May 25, 2016 | Office Equipment & Supplies
Copier Gestetner Dsc530 (or Ricoh Aficio mp c3000) has error SC501 - tried to reset, but need to replace thermistor. Can't find a diagram on where it's located on the fusing unit. Anyone?
Error code SC501 is not a fuser problem. It is the top paper feed tray. Take all of the paper out of tray 1 and turn the machine all the way off. Turn it back on. Code should be cleared. If it returns with no paper in it the paper feed station has a broken part and can only be repaired by replacing it.
Nov 04, 2013 | Gestetner Office Equipment & Supplies
A small white plastic piece has broken off the bottom of the printer. I am not sure where it has come from. I think the paper carrier may have been forced and caused this problem. Now the printer is not...
In my experience, what you say might be correct. The small white broken piece could be the arm that comes down and touches the top sheet of paper in the tray, so it knows how much paper is loaded. When there is no arm, it can not recognize that there is paper loaded, thus NO PAPER FEED. I have fixed one of these in the past, but I had 2 identical printers to mix and match parts. I am not sure what it will cost you, you would have to call the repair center and find out. It took me about 2 hours to fix, so I hope a professional could do it faster than that.
Mar 14, 2011 | Brother DCP-585cw All-in-One Wireless...
Need paper feed gear for Minolta 1250W printer
Try to find the local minolta service and try to order over them. Or go in few printer repair shops and try to find similar one.
Where are you located?
Jul 07, 2010 | Minolta PagePro 1250W Laser Printer
Screen says
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything! You will need to see an authorized service center for repair.
Jan 27, 2010 | Brother MFC 210C All-In-One InkJet Printer
Is there laser fax model 612? Its the same as 611 or not?
Yes those Panasonic models are the same just the KX-FL 612 is different from KX-FL 611 in some specifications like as example:
611 prints maximum 14 pages per minute and 612 prints 16 pages per minute. The document feeder on 611 can feed maximum 20 pages while 612 can feed 30 pages and some other compare stuff like those.
Mainly KX-FL 612 is improved version of KX-FL 611
Jul 11, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Sep 25, 2008 | Ricoh Aficio 450 Copier
Paper will not feed in Canon Pixma iP6000D printer
hi, clean the feed roller or get it cleaned from an authorized service center. use good quality paper
thanks
Aug 02, 2008 | Canon Pixma iP6000D InkJet Photo Printer
Paper not going down
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Dec 26, 2007 | Royal Orca ASF5000X Shredder
Panasonic model no kx -FL 512cx fax machine
1-use fresh papers and fan it .
2-clean paper feed roller carefully.
3-confirm that no foregin object droped inside.(pins etc..)
4-confirm that gear train working propably and there is no broken gear.
Nov 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
47 people viewed this question
jasbo
jasbo
