Question about Asko W6021 Front Load Washer
Asko quattro 1400rpm .display reading motor
I am a appliance repair student trying to fix this macine with no info on it what so ever. when put into wash mode it briefly alows water in than states wash motor fault. any ideas or info would be much appreciated.
Jim Truman college Chicago IL werdevo@yahoo.com
  • chupi Apr 25, 2008
    no solution given
  • 770 Answers
Check your email
Posted on Apr 23, 2008
I have Asko washing machine W600/Quattro 1000 and it is not closing the door all of a sudden - so not able to do washing.
Try lifting up on the outer bottom corner when shutting the door, if it shuts that way then there is probably a loose screw on the hinges that needs tightening.
Jan 25, 2017 | Asko Washing Machines
Where can I find what the codes stand for in display
probably the manual or the manufacturers website
search ..display codes <manufacturer> <model#>
Nov 15, 2016 | Dishwashers
Asko 20004 washes but won't spin
This is a motor fault issue. As I don't know your ability in repairing or what tools you possess. Simple solution: other then have a repairman do this, the motor has something causing a fault. The vast majority of times in an asko because the motors spin at high speeds then most others is that the brushes wear out. So they most likely need a repair. Turn off machine, remove motor replace brushes. There other possibilities such as electrical problems but I reckon brushes are the problem, could cost $60 for the pair and takes maybe an hour or two depending the skill of the person attempting. This is not complex just dirty I do not endorse repairing any appliance without proper experience in repairing appliances. This is only informative.
Nov 18, 2013 | Asko Washing Machines
There is an error code of F 06 that comes up on the washer display. What does that mean?
Before changing components on this unit I like to remove and reinsert all wire connections at the board and motor. This tends to clean the small mount of corrosion that will build up on the connections. After you do this put the machine into a service cycle. The instructions on this is in the tech sheet ou found inside the unit. Part of the service cycle is running the motor at certain set speeds which checks the tach. Good Luck!
Read more: Whirlpool Duet F/06 error code - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/10059.html#ixzz1BErA2200
Get appliance parts at http://parts.fixitnow.com
Jan 16, 2011 | Maytag EPIC MFW9700S Front Load Washer
Door latch switch failure
no you need to replace the door lock assy
Jun 13, 2010 | Asko W6441 Front Load Washer
My ASKO 2805 is leaking from the bottom during washes now...i think the gasket or something might be aged....where can I get parts and is this the typical repair problem.
yes it is probably leaking from the motor seal if they dry out at anytime they tend to leak or it is just age it is located at the top of the motor usuallky in the centre of washer in bottom...I suggest you call a good appliance repair and parts shop and ask about your particular model give the model no and year if you have it....good luck
Dec 25, 2009 | Asko 24 in. 1805 Built-in Dishwasher
What kind of motor installed in hotpoint washer/dryer model No. WD420P
It is a brush type motor, rated at 1400rpm.
Runs on mains 240v
Trust this is the info you require.
If you need more info, e-mail me.
Thanks.
Dec 06, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Asko W6021 Front Load Washer Logo
127 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
