posted by deanie3110 on Apr 23, 2008
Ice maker does not make ice and the in-door water is not working properly - it keeps running.
Solution #1
posted on Apr 23, 2008
the water in the door problem after you fill up your cup with water it keeps running all over the floor.. it sounds like its a stuck contact on a micro switch inside the door compartment. that lever you are pushing your glass onto is atached to a little switch and if the contacts stay closed (like when a glass is pushing on it) the machine thinks "hey he still wants water". next time it does that try pushing on the spot you put the glass onto a couple of time to see if it stops the water. if so it most likely is the switch. to confirm that is the case you will have to open the plastic moulding from the fridge door to gain access to the switch.( always unplug any electricall device before openning to ensure your hair doesnt end up standing striaght up like a punk rocker) you will know which switch is the one you want to check by depressing the water lever on the front. Ohm check the switch for continuity to see if it gives you proper readings or it is in fact a bunk switch. it also could be a mechanical problem as the lever once unpressed is not opening the switch back up once the glass is removed but that is not as likely unless you are ramming the glass into the water dispensor
hope it helps
VeeDubb
hope it helps
VeeDubb
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
GE Profile PSS26NGS Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
GE GSS22JFMWW Side by Side Refrigerator
Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Can you Help with these Refrigerators problems?
GE PSS25NGNBB Side by Side Refrigerator
GE refrigerator SXS PCS25NGSABB
I have been having a problem... Answer This...
Frigidaire FRS-26DR7D Side by Side...
exterior finish on stainless...
I have a Frigidaire... Answer This...
Kenmore Elite 22.4 cu. ft. Bottom Freezer...
error code
error code
frige has error code IF doesnt... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
