Question about Hoover H130E Front Load Washer
Door on the Hoover washing machine, model H130E
The door on the washing machine is shut, however the light on the control panel indicating that the door is locked won't come on which means the washing machine won't run the wash cycle!!
I've tried pushing the door firmly, switching the washing machine on and off but nothing helps!! I'm completely lost, the washing machine is only 3 yrs old!
Any ideas!!
Many thanks
  • 101 Answers
Make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
Posted on Apr 23, 2008
My hoover dynamic wash 7+ door indicator flashes in spite of door being closed properly and machine wont start
the door interlock has failed and needs too be replaced
you can find this easily changed out part on ebay or from spares suppliers
you usually need to take the top off the machine
power off and open the door and remove the two screws at the lock
reach down and take out the interlock mecha
plug in a new one and put it back and screw it back on
very easy...
Feb 08, 2015 | Hoover Washing Machines
The door hinge has snapped is it easy to take off and replace.
Two screws hold the hinge to the frontplate of the machine which goes into a threaded nut welded to the panel (torque to 30/40 foot pounds or relatively snug).. just remove the screws and raise the hinge and pull forward..(keyhole slotted on)... then reverse to attach the new door...
Jun 06, 2011 | Hoover H130E Front Load Washer
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Hoover H130E 'Superwash' and start light flashing after cycle....
You might try unplugging the power cord for 5 minutes, then restore power again. Try the machine again--if still has problems (beat son severely), you may have to replace the control unit.
Aug 11, 2009 | Washing Machines
Can't open the door timers saver & 1200 spin lights flash
There is a known problem with these washers whereby a small electrical current 'leak' from the heater element causes the machine to think it still has water in it.
Disconnect the wires on the heater (tape them up or otherwise make safe) then run a cycle to verify that part as the problem.
Jan 31, 2018 | Hoover H130E Front Load Washer
L g washer
is water still in the machine. if so check the pump (the little door at the base of the machine) first use that little tube to drain the water. there is a safety feature on front load washers that does not allow the washer to open if it is full of water
Dec 20, 2008 | Hoover H130E Front Load Washer
Hoover H130E Front Load Washer Logo
258 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
