I need a manual for Imperial GV 20030812 motherboard
    President:
  • 2,712 Answers
Hello Lexyk,
Here the link for manual
http://www.emachineupgraders.info/di...ownloads.shtml
and the main page http://www.emachineupgraders.info/di...imperial.shtml
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
"Discover How to Achieve Your WILDEST DREAMS"...Free Download
FREE SOFTWARE GIVEAWAY
Windows Utilities - Software Street
Posted on Apr 23, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Emachines Imperial GV 20030812 Motherboard manual
THE MOST EASY WAY TO CLEAR CMOS JUST REMOVE CMOS-
BATTERY FOR 10-20 SECONDS.IT LOOK LIKE A WATCH-BATTERY.BE CAREFULE WITH THE HOOKS.
Dec 03, 2013 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Where to find manual for motherboard 143159 imperial Gv 20030812?
Good luck. Used to be you could get a mobo manual from e4allupgraders.
The Imperial board is made by TriGem
Started out as TriGem Sambo, is now TG Sambo
The Imperial models were Imperial G, Imperial GL, Imperial GV, and Imperial GLVE, if memory serves.
TriGem Imperial GV - 143159 -20030812
http://www.ebay.com/itm/gateway-emachine-mother-board-imperial-gv-20030812-/111025938736?pt=Motherboards&hash=item19d9a96130
Bad photo, but it does have the mouse Zoom In feature.
CMOS jumper and Clear BIOS Password jumper, down by the Front Panel header; is the same as used on the TriGem Imperial GLVE -129504,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07540&lc=en&cc=us&product=83481
Scroll down to Motherboard Layout (Illustration), and Photo; then down to jumper info.
(By the way.........the BIOS chipset is removable, therefore replaceable)
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
This is PANEL in the illustration. Bottom/Right corner. Uses the same Front Panel pinout, as your Imperial GV uses.
8 pins along in a row.
Starting on the LEFT side going towards the Right;
Pins 1, 2, 3, NO pin 4, 5, 6, 7, and 8.
A) Pin 1 is N/C. Not Connected
(May not even be there for all I know)
B) Pins 2 and 3 are for the Power On LED.
Pin 3 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
C) There is NO Pin 4. At least that is what I make, looking at the Front Panel header pinout. Indicate Pin 1 is N/C, and Pin 4 is N/C.
D) Pins 5 and 6 are for the HarDDrive activity LED light.
Pin 5 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
E) Pins 7 and 8 are for the Power On switch.
HOWEVER, since the motherboard photo on HP Support, and Ebay; is as clear as mud; suggest you do this,
Connect your Power On switch to Pins 7 and 8;
OR,
touch across them briefly with a small flat tip screwdriver.
(Power plugged in)
See if that is correct for the Power On switch. What will happen if it isn't? Nothing. Pressing the Power On button just won't turn the computer on; is all.
Turned the Power Supply (Computer) on?
Good. We can assume the rest of the pinout is correct also.
Want to make sure? Easy.
Take an LED bulb (Power On, or HDD), and touch it's two wires to the Power On LED pins, in the Front panel header.
Stays on? Yep. Power On LED pins.
Blinks? Whoops.
Those are the Harddrive activity LED pins.
Just that easy to check it. With using an LED, you won't harm anything even if the pinout is wrong.
Moving on.........
Using the HP Support page, for that TriGem Imperial GLVE motherboard, the Motherboard Layout is the same as the Imperial GV.
(So is photo, 'natch)
Referring to the layout, and photo;
A) Power cables:
Two
20-pin ATX main power cable, and 4-pin ATX +12 Volt power cable.
General example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note* Color of power cable connector does NOT matter.
Can be Whitish, Yellowish, Black, Sea Foam Blue, or Lactating Mammary Gland Pink. (Made the last two up)
Goes to the motherboard connector immediately above PCI slot 1.
Note the LOCK on the side of the power cable, and corresponding TAB on the motherboard connector.
General example of 4-pin ATX +12 Volt power cable, and connector on motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power for the Processor
Looking at the motherboard illustration, look at the Northbridge chip; -> Intel 845GL in the middle.
ATX 12V to the left, is where the 4-pin ATX +12 Volt power cable plugs in.
See the aluminum finned Heatsink, sitting on the Northbridge chip?
The whitish/yellowish 4-socket hole square connector, to the Left.
Moving on............
See where it states Primary IDE to the bottom/right in the illustration? Blue IDE connector?
That is where the Harddrive plugs in.
This is a general example of the connector,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
Note the Locating Lug on the top/middle. This particular style uses two ribs. Some are just a solid block.
The reason I brought it up, is if there is NO Locating Lug on the connector; let me know in a Comment.
I'll tell you how to use the faint Red stripe, on the side of the flat cable; in order to plug it in correctly.
The optical drive (CD/DVD drive) plugs into Secondary IDE.
You can see where a Floppy Drive plugs in.
Above the Processor (CPU) socket to the Right, is where a computer case fan plugs in. PS_FAN.
To the upper Left, is where the Processor fan plugs in.
CPU_FAN
To the left of the ATX Power Connector, (20-pin ATX main power cable; motherboard connector), is the connector for the small audio cable; coming from the optical drive. (CD/DVD drive)
Optical Drive In.
Right next to the round CMOS battery, is the Front Panel USB header.
-> TWO USB ports connect to this header.
(USB)
A 4-pin Peripheral power cable is used for the Harddrive, and Optical Drive.
Misnomered as 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the rounded corners. When plugging the power cable in, these rounded corners always go UP.
[Molex was the first maker of the power cable connector.
The name stuck.
Kind of like calling an adjustable open-end wrench a 'Crescent wrench' ]
The motherboard chipset is an Intel 845GV.
This is what Processors (CPU), and Ram Memory are supported,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Single-Core processors.
Use a Socket 478 processor socket.
Intel Pentium 4, Celeron, or Celeron D.
(Celeron D is NOT a dual core processor)
400 to 533MegaHertz Front Side Bus processor support.
(400/533MHz FSB)
DDR Sdram ram memory that is either 266MegaHertz, or 333MHz.
(PC2100 and PC2700, respectively)
2GB's of it.
1GB for EACH ram memory slot.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 08, 2013 | eMachines Mb, 143159 Imperial_gv 20030812...
I need display driver plz help me imperial 20030812 display drivers downloads
Hi, you can download the driver here:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=2&modelId=1434
If not the right driver search by model and number.
The driver maybe needs to be unziped before installation.
Hope this will help you.
Mar 30, 2011 | E-Machines EMA IMPERIAL GV (845GV) TG3...
I put W 7 32 bit on imperial GV 20030812 but the resolution of the video is not good, can you help please with of controller?
Hi Good day!!! Try to upgrade your direct X click here http://www.microsoft.com/games/en-US/aboutGFW/pages/directx.aspx if still bad maybe your graphic hardware is not compatible for windows 7, by the way what operating system you use before you install windows 7?
Please reply if you have further problems i will assist you more
Thank you for using FixYa
Please accept if my solution helps you
Nov 10, 2010 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Need jumper pin config settings for imperial gv 2003 i need to know what j-5 is for mostly
This MB is very similar to Intel 845 boards. The info is similar & if you had mentioned which jumper's, then maybe.. otherwise this is the specs of imperial:
143159 Imperial GV 20030812
Mat,no:143XXX IMPERIAL-GV200XXXXX E-Machines Socket 478 Processor Socket Type: mPGA478 Memory Type: Unbuffered DDR Synchronous DRAM (DDR SDRAM) Memory Speed: PC2100/PC1600 Memory Sockets: Two 184-pin 2.5 V DIMM sockets Maximum Memory: 2 GB 256Mbit Memory Support: Yes Front Side Bus: 400MHz Intel: Extreme Graphics (845) AGP Manufacturer: Intel Bus: AGP Chipset: Intel 845 Video RAM Type: Uses system memory Onboard Audio Configuration: Intel ICH AC 97 CODEC AC'97 Codec Device: AD1886 Audio Jacks: M, LI, LO, (Header) SO Speaker CD-In Connector: 1 Internal Spkr-Out/Line-Out/Headphone-Out/Mic-In Header: Yes Onboard LAN Onboard 10/100Mbps Ethernet LAN Supplier: Realtek RTL8100(B) Ethernet Configuration: Down(PCI) Wake-on-LAN, Wake-on-Ring: via PME#(PCI) .....................sodeep
Sep 13, 2009 | E-Machines Computers & Internet
Looking for manual to hook up power, reset,and leds on imperial gv 20030812 motherboard
Hello Laws 1957,
Here is a more or less universal pinout diagram for your motherboard. I sincerely hope this is in or was from an eMachine PC.
http://www.e4allupgraders.info/dir2/images/switches/imperialfntpanelom4.jpg
If I find anymore information for you I will be sure to post it. Good luck with this.
Jul 13, 2009 | Computers & Internet
Graphic Card
jumper settings for old graphic needs to be disabled or in the bios settings the on board vga settings need to be disabled this will allow the other new card to be ran as the dominent only video card
jumper settings are tricky
but bios settings are easy just find vga and disable on board video thats it save and boot
Jun 04, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Computers & Internet Logo
417 people viewed this question
David Payne
David Payne
