Question about Canon PIXMA iP1800 InkJet Photo Printer
INK CARTRIDGES PUT IN NEW CARTRIDGE KEEP GETTING ORANGE LIGHT FLASHING SAYING CARTRIDGE NOT INSTALLED PROPERLY.PUT OLD ONE BACK IN STILL HAVE SAME PROBLEM
  • Anonymous May 09, 2008
    i KEEP GETTING A MESSAGE THAT ONE OF THE CARTRIDGES IS NOT INSTALLED PROPERLY WHEN I TRY PRINTING. THE CARTRIDGE IS INSTALLED PROPERLY AND ALL CONTACTS ARE CLEAN. I AM STILL USING THE ORIGINAL CARTRIDGES THE MACHINE CAME WITH SINCE IT IS ONLY ABOUT THREE MONTHS OLD.
    Genius:
  • 3,587 Answers
Turn off printer...check the bottom of the printer cartridge for any blockage or film
Posted on Apr 24, 2008
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
U150 error on canon mx885
Solution 1:
  • Open the paper output tray.
  • Turn on the printer and open the scanning unit. The printer cartridge carriage will move to the center. Open the inner cover securing the cartridge in place by pulling it downward.
  • Press the tab on the problematic ink cartridge and lift it to remove it from the printer. You will be able to tell which ink cartridge is causing the problem because its indicator light will be off or flashing.
  • Open the replacement ink cartridge and pull the orange tape in the direction of the arrow to remove the protective film. Tear the orange tape off along the dotted line.
  • Place the ink cartridges into the printer and press where indicated on the cartridge until it clicks into place. Ensure that all ink cartridges have a red indicator light showing that they are properly installed.
  • Close the inner cover on the cartridge carriage and the scanning unit. The printer will automatically start a print head cleaning cycle. When the cleaning cycle is complete, the printer is ready to use.
Solution 2:
  • Put the little green circuit board from the old ink cartridge of the same color in the new cartridge.
Apr 17, 2012 | Canon Office Equipment & Supplies
Canon iP2600 Printer yellow light flaxes message says an ink cartridge is not installed properly
have you tried cleaning the printheads ?
There is an option for cleaning head in printer's properties : select this and you will be able to clean printehads for the canon iP2600
Jan 19, 2012 | Canon Pixma iP2600 Photo InkJet Printer
Under Attention, orange lights are flashing for black and white and color. I have put new ink cartridges in turned on and off and still flashing orange. Wher it says Start/Copy, a big E is flashing. ...
I would try to remove both ink cartridges.
Close cover and turn off printer and unplug from outlet.
Wait at least 15 minutes, this will let printer to completely reset.
Turn on printer and wait for printer to stop.
Install both ink cartridges.
Jan 09, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
I have installed 2 new ink cartridges. The orange
Are the cartridges genuine new hp, or are they compatibles, or refills? If not genuine hp, get some and see if that solves your problem.
Apr 25, 2010 | HP Photosmart C5280 Printer
Orange cartridge keeps flashing after cartridge
Are you using a factory new HP ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
Don
Oct 22, 2009 | HP Deskjet 6980 InkJet Photo Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
The orange lamp always lights
depending on how many times the orange light flashes. if 4 flashes then the ink has run out. if 5 flashes then it can not recognise the ink cartridge, if 7 flashes then the ink is not installed properly.
Mar 31, 2009 | Canon PIXMA iP1800 Printer
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
204 people viewed this question
old marine
old marine
Corne Viljoen
