Question about Sewing Machines
Kenmore Sewing Machine 16221 will not feed
I just bought this machine a couple of months ago. It was working fine and then it stopped feeding the fabric. I took it apart and cleaned it. The feed dogs seem to be working just fine but the fabric will not feed. It just stays in one place and bunches up on the bottom. This problem started yesterday, then it was working fine again and now it's doing the same thing.
  • kccat5 Dec 09, 2008
    I have a celebrity S 210 and the feed is not working nor is the reverse clutch.
  • Sewing Machines Master
  • 1,388 Answers
Check for lint buildup between the feeddog teeth, will look like felt pads.....remove it !.........this little housekeeping should be done regularly......also ensure the correct stitch length is selected, not set at zero (OK, unlikely, but can happen !!)
Posted on Apr 24, 2008
What year 16524 and 16221 sewing machine made Kenmore 385 series
Couldn't find the year, but I think the 16221 was made in Canada. Here is the manual - it's 110 pages long! https://www.manualslib.com/manual/666395/Kenmore-385-16221.html#manual
Couldn't find anything on the 16524
Nov 19, 2017 | Kenmore Sewing Machines
I have an Emerald 116 Husqvarna/Viking sewing machine and the feeder teeth have simply stopped feeding. It worked fine the last time I used it a couple of months ago and it hasn't been moved or disturbed...
HOW TO FIX YOUR FEEDER TEETH (DOG TEETH) ON EMERALD 116/118/120 IF THEY STOP WORKING....
So this is just a temporary solution to this problem... after reading through the user's guide (which really needs to be updated to have more troubleshooting suggestions), and basically taking apart various parts of the machine, I found a temporary solution.
1. Unscrew the Face Place (where the needle is attached to. #9 in User Guide Overview) There is only one screw on the side right underneath the Pressure Foot Pressure Dial (#8 in User Guide Overview). Taking off the Face Place gives you room to use a screwdriver for step 2...
2. Unscrew the Needle Plate (#12 in User Guide Overview), and take out the Bobbin holder (black). Slide the lever for the Feed Teeth to the raised position, and with your forefinger pop up the Feed Teeth (underneath the needle) to the raised position. You will here a click... and you are set to go. Reassembly your machine and get back to sewing!
Nov 21, 2010 | Sewing Machines
We have a Kenmore sewing machine Mocel 385.1764180 and the material will not move while sewing a straight stitch. My wife says it did this a couple of days ago and corrected itself by moving a couple of...
on my machine, as janome, there is a feed dog lever behind the bobbin are, and a pressure foot adjust on the top of the machine. But idf you have touched those perhaps something is catch in them and thats why it keeps happening ??
Jan 10, 2010 | Sewing Machines
Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Oct 06, 2009 | Kenmore 16622 Mechanical Sewing Machine
Not feeding.
Check to see if the feed dogs are up, maybe you somehow clicked or switched a button, it happens to me some time when I take the bobbin out and put a new one in. I don't know your machine but some machines have the lever/knob for dropping the feed dogs in a strange location.
May 25, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Feed dogs not feeding the material
Is this a second hand machine ?
Is the stitch length selector set to > 1
Remove the needleplate and clean between teeth of feeddogs if it has been a while since this has been done, old lint will impede feeding.
Presser foot tension for general work needs to be set at 3, or the chromed button pushed down to the grooved line, depending on machine.
If new, call the dealer where you bought it and speak to them.
Nov 24, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Owners manual
Sears Parts Direct (800)366-7278 or an online site tha has them. Sears/KMart should have provided that for you!
Aug 29, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Kenmore Model 16221 sewing machine
your machine needs to be clean take it down clean and oil it up and you will have that problem no more.good luck.
Jun 03, 2007 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
140 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
