Question about Refrigerators
Maytag MFI2568AEB- icemaker flapper keeps slapping open and shut. water and Ice dispensers not working and "5" and "35" flash rapidly on the control panel and all lights flash and flicker rapidly.
  • 3 more comments
  • 3154 Apr 23, 2008
    yes, i also have this same problem..lol and the same day as motor'z...i removed power for 1min restored service working good for 4-5 min and started again..
  • Anonymous Jun 13, 2008
    Yep, we're having the same identical problem.
  • Anonymous Aug 07, 2008
    talk tot a buddy of mine, the sensor in the back of the the main control panel is out. also my control panel might be out.
  • Anonymous Aug 16, 2008
    the panel lights are going nuts and the flapper keeps opening and closing. We just got the water hooked up so we could use it and then this happens!
  • lizeb Feb 15, 2009
    i have the same problem tried to replacve the comuter board and now will not get cold i do not know how to program the new pannel
Replace main control board known as the hv board part number 12920710 Ive replaced many the reprogramming code number is on the model number sticker the instructions for reprogramming are in the Tech Sheet located under fridge behind front grill rh side stuck to the top of the bottom in plastic bag new board will not work without reprograming Can you solder? replace the 2 680 microfarad caps located on the board located lwr center next to the china sticker they are side by side and the tops of these caps apear to be bubbling out. Mouser.com mouser part number 647-upw1v681mhd caps are less than a $1 a peice and new board $180
Posted on Apr 03, 2009
  • ejmetz Dec 29, 2011
    What an awesome fix - thank you very much! Just saved me a $200 control board or a $500 service call. Radio Shack didn't have the 680 microF caps, but did have 470 and 220, so connected them in parallel (parallel caps add values). Fridge works perfectly!
  • At1bob2006 Jan 13, 2012
    Glad I could help I forgot I posted this I thought this problem went away with the new boards
I can see that the two capacitors on the board are defective. i will replace in the morning and report back......
Posted on Mar 02, 2010
  • johnnie529 Mar 08, 2010
    ok, i finally got my capacitors, but i had to get 680 uf 100v. the capacitors are rather large for the designated spots on the control board, but they fixed the problem. everything is working now, but i will reorder 680 uf 35v capacitors and replace them later. the high voltage control board would have costed me around $190, but the capacitors were $1.67 each (2). the control board comes out with no problems and the capacitors are easily identifyable by the bulges on top of the capacitors.
  • 145 Answers
The high voltage control board is out. It is on the back of the unit. Unplug unit before replaceing.
Posted on Apr 24, 2008
Talked to a buddy of mine. sensor in behind the control panel is out. not the flapper. also contorl panel might be out.!
Posted on Aug 07, 2008
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Slow water dispenser on mfi2568aeb
There will not be a one word solution to this but if we test the areas beginning with the water supply line we will come to a answer. You need to look at where and how the water line is connected to the water service line. Shut the water supply off at its source. remove the water line on back of refrigerator and point water line into a pan or bucket and have someone turn the shut off back on. If flow is poor then the suppline has a blockage at the tap valve that is (not recommended) or a crimp in the feed supply line to refrigerator. If that turns out to be OK then we move to the dual water control valve part number 67006322 It also may be that the valve is not opening well due to being worn out, I am ready to assist you when you are, Sea Breeze
Apr 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Arctica ice maker won't work without help
The solenold valve would not shut off completely & was leaking water on the paddle that the controls the icemaking. We replaced the solenold water valve & we now have ice!!!!! Good luck!
Feb 20, 2009 | GE Profile¿ Arctica® Energy...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Ice and water dispenser for Maytag H20 not working
You need a new high voltage control board. Ive had at least 10 do this.
Oct 05, 2007 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
1,510 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
