Question about Hitachi 46F510 46" Projection HDTV
HI i have a 42" Hitachi HDTV 1080p (LCD)
The problem is this.
With HDMI cable it works wonderful!!!!! PS3 games look amazing
But, signal from my cable provider or playing wii, the signal is very blurry. Is it the TV of the provider....
Please help
Adam
    Scholar:
  • 186 Answers
Most newer Digital TV's don't display Analog signal very well. Often worse then an Analog TV. This is normal to a degree. If your Wii has component  cables, try using that. As for cable, you might get a better signal with Digital Cable.
Posted on Apr 23, 2008
My Viore 42" LCD HDTV's HDMI inputs currently make the TV's picture signal intermittent when reading a signal from my comcast cable box and a few functions of my PS3. How can I fix this?
You might need a firmware upgrade. If there isn't one,then you might have a defective main board, or your set is not 100% compatible with your other items.
Mar 21, 2013 | Viore 42" Class 1080P 60Hz Lcd Hdtv
Insignia 26" HDTV 1080p, I just bought it the
First off what type of input are you using going from the ps3 to the tv. If your using HDMI try changing the different video settings. Black ops actually has a lot of problems right now on ps3. So I wouldn't use that as the basis of what is working or not, I would try other games to see if it's working. Adjust the video settings on the ps3 and see if that helps. If that doesn't try using component cables and see what that does for you.
Thank you,
Lee
Feb 01, 2011 | Insignia 42" LCD Flat-Panel HDTV
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hi ..I was wondering if Playstation 3 and the blue ray features would work with my Maxent MX-42VM10 Plasma Screen TV? Thank you ...kev
Yes and no.  Yes you can connect the PS3 to the plasma using the component video inputs, games and videos will play fine.  However the native resolution of the TV is only 480P (852X480 pixels) which is much lower than the 1080P that the PS3 is capable of.  If you want a tv that can get the best possible image from the PS3 you would need a TV with full 1080P resolution and HDMI ports for digital input. Hope this helps!
Nov 29, 2008 | Maxent MX-42VM 42 in. Plasma HDTV
Help
Best would be hdmi next would be component, both can carry 1080p signal, but hdmi beats component as it can upscale to 1080p.
Jan 21, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
You may want to try a good, Monster Cable, HDMI cable. Visit this page: http://www.monstercable.com/HDMI/advancedhdmi.asp
If you have a standard HDMI cable, it will not support 1080P.
So this is one of the few times that I will recommend spending the money for a better cable.
The better cable improves picture color quality, from 8 bit to 12 bit and it improves audio quality.
Dec 24, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
PS3 not working thru HDMI cable
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Hitachi 46F510 46" Projection HDTV Logo
173 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
