Question about Refrigerators
Drinks freeze in refrig. area and veggies freeze in crisper. I set the temp as recommended. and then increased it when that didnt work.
  • jkteck Aug 26, 2008
    I have same problem with same model. No matter where I set the control, there seems to be 8 to 10degrees difference in temperature between the top and bottom shelve.
    Genius:
  • 1,073 Answers
What is the model number of the ref
Posted on Apr 23, 2008
My vegetables keep freezing in the fridge, how do i get the fridge at the right temp?
Remove the vegetable/ produce/ meat draws and shelving that support them. Look along the rear wall or the left inside wall for vents that are feeding or directing cold air to the draws. First try to shut or close these vents down. Or you can tape over them to restrict the flow . The normal refrig temp is between 37 to 40 deg.
Jan 20, 2013 | Viking VCSB423 Side by Side Refrigerator
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
The bottom crisper in my refrige freezes my veggies
To repair this problem I dont think just toggling a lever is going to work. You need to locate what is suppose to sense the temp in the fridge section and how it stops the air flow to the fridge section. Basically most refrigerators cool in the freezer using the freon coils and transfer the cold to the fridge section using the fan in the freezer. Then your thermostat (temp sensor) stops the air flow by either turning off the fan or closing a small door going to the fridge section. This door is called the baffle and if you put your hand up to it and can still feel air coming thru when the temperature is 39 degrees or lower its not doing its job. With a model number I could help better but my guess is if its not freezing everything only the veggies your thermostat is off or the baffle is unable to close all the way and may have ice or debris in it. Either way I hope this helps.
Jan 24, 2010 | Refrigerators
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Crisper draws are freezing produce. Kenmore Trio 795.77562.600
If you can find the duct work behind the draws you might find an air control, if you have a contract with Sears - you can call them back, the part that was replaced has a Garn.T and or 30 days on service, when you ajust the temps it may sometime act up but has a default and will return to that. Cold air drops down. read the manual that came with the Refrig. Buying a service contract might be the best thing for piece of mind - Sears covers everything, even plactic and paint ( scratches). most everything is plastic in the refrigerators today and are very expensive, 3 doors allow more air into the unit then a 2 door because of the seal between the doors, just 2 pieces of rubber overlapping .
Act on this as fast as you can, 30 days on service goes fast and a service call runs about 75 dollars . Oh ! don't put wet veggies in draw and rap everything with Plastic wrap, veggies only least about 4 /5 days then become soft and lose taste and color.
Jul 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Crisper and veggie bins are freezing the produce
I have dealt with bosch and thermador quit a bit and they usually don't have to much of a recommendation for these settings because they are more of a commercial type appliance producer and all situations are different. Here is a tip for the sliders though. Remember that leafy produce needs more airflow to hold its texture and taste and anything with a skin requires less airflow. As far as the temp settings I believe the most nominal settings are going to be in between 5 & 7 to keep from freezing the produce. You will have to play around with it a little though to get it to keep the ref good and cold but keep from freezing the vegies. Hope this helps. Good luck.
Jun 05, 2009 | Bosch KGU6655
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
