Question about Harman Kardon HK 3370 Receiver
Blown Fuse Every time I turn on the receiver, it blows a fuse. The fuse is towards the rear of the unit. It is a 5amp 125volt. Soon as I hit the power button the fuse blows. Any suggestions?
  • Anonymous Apr 27, 2008
    Every time I turn on the receiver the fuse blows. It's a 5A 125V. This just happen all of a sudden.
    Scholar:
  • 186 Answers
It's drawing too much power. Maybe a short in an amp. Do you have any warranty left? Double check to make sure you have the right fuse. You might also try a slow blow fuse so  you can turn it off right away as soon as the fuse starts to glow to help in diagnosing.
Posted on Apr 23, 2008
15 amp fuse blows and no running lights. What's wrong?
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and connect it to the power side of the, circuit breaker or the blown fuse receiver, start by tracking the out bound wire towards the ignition switch and beyond if necessary, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Apr 06, 2012 | 2006 Harley Davidson FLHX Street Glide
Fuse keep blowing
Means that item the fuse is protecting is bad.Fusing unit is a good start replace it
Apr 01, 2010 | Office Equipment & Supplies
I have a pro-sound 1000 which keeps blowing plug fuses Can you let me know what fuse should be in the plug as this maybe the problem
The fuse in the power plug is there to protect the cable. The fuse in the plug should be the same as the cable. For instance a 5amp cable should have a 5amp fuse. If the fuse blows all the time the cable could be faulty or there could be an overload in the power supply (perhaps the transformer has failed) that is causing the supply to draw more amps than the cable and fuse can cope with.
WARNING fitting a fuse higher than the cable rating could cause the cable to overheat and catch fire!
Mar 07, 2010 | Audio Players & Recorders
Head unit keeps blowing fuse for interior electronics of durango
go for a new fuse
if it is 10A go for 15A
add +5Amp fuse to your present fuse
and then try
Regards
reply by a Vote
Sep 21, 2009 | Alpine CDA-9827 CD Player
HTR-5280 Receiver Fuse Blown
the fuse rating should be printed at the back near the fuse holder itself. If it opens the fuse again and again probably you have a circuit loading problem in the receiver...either one of the amps is failing.
Aug 10, 2009 | Yamaha HTR-5280 Receiver
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
Reciever
Did you try unplugging the unit and taking the cover off and seeing if the internal fuse is blown? There maybe a fuseholder on the rear of the receiver too. It is usually black, 1/2" in diameter, with a twist off cap and the marking of the fuse rating in white. If not, you'll have to take the cover off and look for a blown internal fuse. If the fuse isn't blown, you could have a faulty on/off switch or power supply. If you replace the fuse and it blows again, then something has failed and is drawing too much current and causing the fuse to blow. It could be a bad power supply or a shorted audio output module. If that is the case, it will need to be taken to a shop to be serviced.
Let me know if I can be of further assistance to you.
- Jim
Feb 07, 2008 | Audio Players & Recorders
Blown Fuse, needs fix'n
You CAN open the unit (keep in mind that even unpluged there is still voltage runing through the system, so.... dont fry) and you will notice, if the face of the unit is towards you you will see on the left hand side a power supply board, the fuse is on that board, and it is a tube fuse, 125V 8A. Most stores do not carry the 125V version anymore, but will carry a 250V. This is okay to use where the voltage is not the main purpose of the fuse.
Oct 19, 2007 | Onkyo HTR500 Receiver
Open Questions:
See all Harman Kardon HK 3370 Receiver Questions
Harman Kardon HK 3370 Receiver Logo
440 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
