Question about Refrigerators
My freezer stop freezer about 3 days ago. The refrigerator get's cold but doesn't freeze. Do you think it needs freon? It's only a year old this month. It is a Friderdaire stainless steel side by side model.
  • cuttie7 Apr 24, 2008
    This was not helpful. I already knew to do that but they can't come out for another week. Thanks anyway!!!
Should be warranty inside a year they may pay
sounds like thermocouple to the freezer to me
Posted on Jul 31, 2008
    Genius:
  • 1,073 Answers
Call frigidaire for factory service person to come out and solve the problem
Posted on Apr 23, 2008
I have a 21 cubic refrigerator with ice maker. its only 3 years old. just 3 days ago, the refrigerator section stop getting cold. but the freezer still works. i checked out the back of the frig to the...
Inside the freezer, at the back is another fan that circulates cold air from the freeze through out the fridge. Make sure it's running. Sometimes the blade will slip on the shaft and get jammed, or the motor could be defective.
Jun 20, 2010 | Whirlpool Microwave Ovens
Kenmore refrigerator stopped cooling 6 days ago and started working again 2 days later but not very cold.Stopped cooling again 2 days ago.Now it is frosted up in the back of the freezer,What could cause...
There are several things that could be causing this. Your compressor could be going bad. Your freon is low. Think of your refrigerator as a air conditioner. Pull it out and vacuum all the dust from your filters, make sure the water is draining properly and not clogged up. Is your unit still under warranty. How old is your unit. Try this. Unplug the unit for about 5-10 minutes, this will give it enough time for the compressor to cool down. Plug it back in and listen for the compressor to kick on. That's the big black round thing at the bottom in the back of your refrigerator. Listen to it and what the sound is, does it click when it turns on, does it shudder when it turns on. Let me know the sound. By unplugging the unit and doing this the compressor should kick on in 1-3 minutes after plugging it back in. If your unit is over 8 years old you might consider another one. Check out craigslist, as you can get some great deals. Let me know if I can help you further.
JimmyC
Sep 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezer not freezing
sounds like your loosing freon.
Jun 09, 2009 | Refrigerators
try unpluging it for 24 hrs with the doors open then plug it back in if it does not change then it could be low on freon it would be best to purchase a new one since it is 15 years old.
Feb 14, 2009 | Refrigerators
Freezer not freezing and burning smell
it may be the compressor overheating it could be the relay but if the compressor is hot then you are low on freon and need to have it recharged
Jan 26, 2009 | Amana ARS2464B Side by Side Refrigerator
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
