Question about T-Mobile Wing™ Smartphone
Deleting Welcome from Wing
The system tells me that I can't delete it because it's being used by another program.
  • 1 more comment
  • Jalarrya May 19, 2008
    My phone is stuck on the alignment screen after a hard reset. I read on here where others have removed the welcome in the file. They said then you could use the key pad only. But when I tried to remove the welcome it states that it's being used by another phone. Which I also have the HTC tilt.
  • vdizzle Jun 02, 2008
    I connected my wing to the computer as i always have. but i dont even know how to get to the windows page file. The directions given on here dont even show up on my computer. How do i get to this file the easiest way possible is it in another file or is it different for vista or something
  • Simon Downey
    Simon Downey May 11, 2010
    Can you be more specific? What welcome exactly are you talking about?
Others have post that if you go in sytem file when you connect your phone to the computer you can delete the welcome file from there and use the key pad on your phone. Because mine is stuck on the alignment screen. Thanks
Posted on May 19, 2008
Can not delete it is used by another program close any program that might be using the file an try again
Reboot the computer and as soon as you get back into windows try deleting the file again. If you get the same message then go into MSCONFIG (type it in the search box) into the startup tab. Disable all the programs and reboot the computer. Try deleting the file again. If you still can't delete it then it may be a system file your trying to delete and those I wouldn't mess with because it could screw up windows.
Last thing to try would be to boot up your computer in safe mode. Since it doesn't load much into memory you should be able to delete your file that way for sure.
May 27, 2011 | Computers & Internet
How do you delete a zone from the alarm system?
Welcome to fixya
I have a solution for this
Content
These alarm systems are best used by setting up each zone first, if you attempt to delete a zone, you risk deleting important configuration information.
Your pre-solution is located above. More information is available in the comments
My name is Bruce
Jan 20, 2011 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Was deleting unnecessary programs off home computer and may have accidently deleted a program but not sure what it was. The problem is whatever I deleted does not allow me to update any programs such as...
Best Bet:
Try going to Programs->Accessories->System Tools->System Restore
Go back to before you began removing the programs. Also, remember whenever removing programs always use the uninstall feature, just deleting them can leave a lot of junk in your registry, cause possible corruptions and lead to sluggish PC performance.
Jan 15, 2010 | Dell Dimension 2400 PC Desktop
I'm tryingto uninstall System Suite 8
on the unistaller screen select the program
try to unistall it them remove the entry
them go to your (hard drive)=(C:\) and open the folder name (program files) select the folder containing the program you try to uninstall and delete the folder containing that particular program
Note: be carefull not to delete the folder name (program files) make sure the folder your deleting is the one containing (the system suite 8)
Jan 11, 2009 | Avanquest System Suite 8: Windows
Unable to sync my T-Mobile Wing with computer
The T-Mobile Wing is not compatible with Windows Mobile Device Center vr. 6.1
My computer had updated itself to the higher version during a Windows update a few weeks ago.
Once vr. 6.1 was uninstalled, and vr. 6.0 was reinstalled, I was able to sync my Wing again.
Jul 01, 2008 | T-Mobile Wing™ Smartphone
Wing touch screen doesnt work
What exactly are you trying to delete?
Jun 02, 2008 | T-Mobile Wing™ Smartphone
Sound problem
you may reinstall this by using your motherboard cd explore cd then select the driver. to avoid from erroneous deleting unnecessary program files, the proper way should be, the system tools then select disk clean up then check items from dialog box which you to delete
Dec 19, 2007 | Computers & Internet
T-mobile Wing - Touch screen stopped working
ok,
finally found the fix for this problem..
i had the same problem -
when you are the welcome screen align section
continue holding your stylus on the marker until marker moves to the next location
and continue this process with all four corners and the screen will go past the tap align screen
enjoy, glad i came across another forum for this problem
Nov 06, 2007 | T-Mobile Wing™ Smartphone
Hpoipm07.exe
Hi
hpoipm07.exeis a process installed alongside HP Printers and provides additional configuration options for these devices. This program is a non-essential process, but should not be terminated unless suspected to be causing problems.
I suggest you to contact HP chat support for further information.
Chat support is free of cost.
Click on the web link given below.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Oct 30, 2007 | HP PSC 950 All-In-One InkJet Printer
T-Mobile Wing™ Smartphone Logo
99 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
