Question about Samsung SGH-D600 Cellular Phone
Samsung slider phone
When i close the slider or open it the screen does not change or calls dot get accepeted or it woujnt end a call when i close phone
  • Nix155 Jun 16, 2008
    when I open my Phone the screen is white and the upper buttens won't work
  • Anonymous Jun 20, 2008
    When i try to accept the call, my phone just went off and restart it by itself.
Go to settings and on slide settings
Posted on Apr 27, 2008
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
on Jan 08, 2010 | Cell Phones
Only hear texts/calls if slider open
change the FLEX -The flexible cord linking the screen part with the panel
Nov 30, 2009 | Samsung SGH-U600 Cellular Phone
Samsung d900i keypad lights are on, screen dead replaced ribbon still same problem ?
I have the same problem but the screen will work as long as I keep the slider open which is not very practical, as soon as I slide it closed the screen goes black and I have to turn it off and on again :( Did you ever find a solution to this problem?
Nov 29, 2009 | Samsung SGH-D900 Cellular Phone
I just gota LG Shine, and when I am making a call and close the slider, the call doesnt end. I cant find a setting to change this. Help Please.
To change this setting. On Menu go to (9)Settings, (5)Call, (2)Answer mode, then you can scroll to (2) Any Key or  (3) Send  key only.
Regards  Bill
Oct 19, 2009 | LG Shine KE970 Cellular Phone
No sound when phone slider up
This is because when the slider is Up then according to the default settings you are using the phone so it donot ring... just shows the displAy... so don'y worry your phone is Ok.
Sep 23, 2009 | Samsung U900 Soul Cellular Phone
Phone stopped working suddenly
This sounds like a flex cable issue. You will need to have a tech examine the device to see if the flex cable needs replacement.
The flex cable is the ribbon cable that connects the screen to the rest of the electronics and allows the slider mechanism to slide and have the device maintain proper electrical connection. After two years it may very well be worn out.
Dec 02, 2008 | Samsung SGH-t629 Cellular Phone
Nokia N95 8GB
This function is not supported by the N95.
There could be several reasons for this:
Not all people like it, people want to answer calls while having the slider closed, e.g because they use a headset.
Also there are several slider positions, and due to multitasking, using several applications at the same time/while calling, it could
Or to prevent ending the call by closing the slider accidentally...
I don't know the exact reasoning behind it.
Anyway, unfortunately this is not possible and the chance that this functionality will be added in the future is small.
Sorry, you'll have to use the end button.
Apr 25, 2008 | Nokia N95 Cellular Phone
Samsung SGH-D600 Cellular Phone Logo
93 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
