Onan 5000 - starts easily, runs for 5 to 20 minutes and then sputters and dies...
If the fuel filter (strainer) is OK, carb gives enough fuel for the load you apply, air filter is dry and clean, your problem may be the low oil level protection.
Check if generator is at level position.
After the oil is distributed in all the engine its level may go less than the measuring sensor level. Try to put some more (not much) oil.
If this will not help your measuring sensor may be bad and switch off when the oil gets hot.
