Question about Philips 42PF7320A 42 in. Plasma HDTV
WESTINGHOUSE FLAT SCREEN TV
WATER LEAKED ON THE FRONT OF SCREEN. IMMEDIATELY DRYED IT OFF. THIS MORNING I HAVE A STREAK IN THE TOP HALF OF THE SCREEN.
    Scholar:
  • 186 Answers
Water damage/stains possible on backlight panel behind LCD panel. I've seen this more on laptops. Does it look like brighter white spots? You might have to take it in to have it professionally cleaned.
Posted on Apr 23, 2008
How to Clean a Flat Screen TV?
Use a screen cleaning solution, very cheap little canister of anti static spray and usually comes with lint free cloth for light polishing.
Couple of quick squirts of solution then very gently wipe over the whole screen until all the dust has been absorbed and the wet streaks evaporate.
Don't need to go mad scrubbing, just light polishing.
A damp cloth is just as good but only damp and not dripping water, just wipe over screen. The only problem with that is it leaves streaks so just wipe over with a dry kitchen towel or something similar.
Oct 19, 2016 | Televison & Video
How do I clean a Samsung tv flatscreen that has had coffee spilled on it? It has been about a week.
Try equal amount of water and vinegar. Spray on clean dry lint free cloth then wipe the TV in the same direction, upand down or side by side...Don't over saturate the cloth...
Feb 11, 2015 | Samsung Televison & Video
How to fix Toshiba Regza LCD TV when half the screen with vertical streaks?
hi this fault sounds like a bad tab/ribbon fault, at top of the tv are ribbons connector to the screen, when one is faulty the heat makes them flex causing this fault, you can bond the ribbon down with a bit of rubber to stop it flexing, but this not a permanent repair as it is a screen fault. hope it helps
regards
shaun
Apr 24, 2014 | Toshiba 42HP66 42 in. LCD Television
Children sprayed water on 46" lcd TV, and it looks
Oh dear! I would check your household insurance if it was an accident, just in case a replacement is required.
Most items that get wet rarely recover without problems.
The water should not be able to get into the screen as it is a sealed. If the water has not entered the TV, you may get away with wiping the screen with an almost dry cloth that has dilute detergent on it, (washing up liquid and warm water is fine). That will remove the streaks.
Nov 08, 2010 | Hitachi Televison & Video
Remove smudge lines on a HD TV
I use clean Dr. from Wal mart it has no abrasive fluids and is for flat screen tv's and lap tops cost 3 bucks for a 9 oz spray bottle and with paper towels it leaves the screen streak free,
Jun 21, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jun 10, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Big screen tv, got wet
my celing was leaking like it was raining out side, but my son ran some bath water and for got he turn the water on and left it ran all over the floor, and i'm down stairs watching the water come down full speed on my big scren tv,i tried drying the tv with a floor heater from front to back wake up the next morning tv still dosen't come on.. what can be the problems,............... please you can reach me at Queenlicious100@gmail.com. i really ned to no i love my tv
Jan 02, 2008 | Televison & Video
Water stain inside of screen glass
Yes, you can check with ctechnicians.com for instructions on disassembling.
Dec 23, 2007 | Hitachi 60EX01B 60" Rear Projection...
Screen
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Philips 42PF7320A 42 in. Plasma HDTV Logo
172 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
