If the errors seem random and incorrect then I would suspect the controller board as being bad. The part number for it is 99001232, looks like it may be hard to find in stock, may be a special order item.
The board will cost you about $200 and shouldn't be too hard to replace. But like I said, I had a hard time finding a website with it in stock. If the machine is mechanically sound as you have stated then it might be worth a shot.
BUT! If you scrap this machine and buy a new one you end up with a better, more modern, machine. Plus it will be under warranty, plus I would consider the extended warranty on something like this.
It all depends what you can afford at this time. Personnaly if I had the money I would buy a newer machine. 10 years is a good run.
Hi firned
u have to go with a good plumber he will charge for
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
h
The machine is about 10 years old. Is it worthwhile to replace the board or is this just the beginning of the end?
