Rhem 2 problem
Followed your directions and changed the properties to compatibility mode. That got me into the next screen, but no further. A big red x popped up on screen when I tired to select the direction I was going to take to start game. Any other sugggestions? Rhem 3 and other games work fine........
4 Suggested Answers
SOURCE: Rhem 2 System requirements
I had this problem "macromedia projector error" Right click on desktop icon, goto properties, click compatibility, put check in "run this program compatibility mode for....... try all choices in drop down menu one at a time till it works. hope i explained it ok? it worked for me. good luck
Posted on Apr 19, 2008
SOURCE: Rhem 2 graphic card
the red x popps up and game freezes on Rhem 2.
Posted on Jun 08, 2008
SOURCE: Remote Control Code problem
I read through other problems on the web page and tried them
Finally I got one of them to work
Thanks
Posted on Mar 01, 2009
When iTunes 10.5.2 is started, PC running Vista 32 Bit, monitor screen resolution changes
Sounds like a compatibility issue. You want to ensure that iTunes is not set to run in compatibility mode. To check this please follow the steps listed below: Step 1. Exit out of iTunes.
Step 2. On the Windows Start Menu select Computer.
Step 3. Browse to the following location: C:\Program Files\iTunes.
Note: Windows 7 (64 bit) users browse to C:\Program Files (x86)\iTunes.
Step 4. Right-click on the iTunes application (iTunes or iTunes.exe) and select Properties.
Step 5. Next select the Compatibility tab.
Step 6. Ensure that the options Run this program in compatibility mode and Run this program as an administrator are not checked. If they are checked please deselect these options, then select Apply, and OK. You should now be able to open iTunes with out receiving the error message about iTunes running in compatibility mode.
Dec 30, 2011 | Computers & Internet
I would like the multi zone code for a samsung V6800 dvd
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
Sep 28, 2008 | Televison & Video
IS THERE A PROGRAM TO ALLOW STAR TREK PINBALL TO OPERATE ON WINDOWS VISTA?
WIndows Vista allows you to run it in compatibility mode for previous Windows versions such windows XP. I suggest you try it and see if it works. To do this, Right-Click on Pinball.exe and click properties
In the properties window there is an option called compatibility. CLick on that tab. Once you click that you will see an option called run this program in compatibility mode for... Click the checkbox next to that and choose Windows XP service Pack 2 from the list
That should most likely do the trick. Give it a shot and let me know so that we can try something else. PS: Bad rating = No Further help!
Sep 16, 2011 | Interplay Productions Star Trek: Pinball...
"Civilization II encountered a problem"
Maybe it isnt compatible with Vista, you can try one thing though try running it by changing its compatibility mode to run on winxp.
Right click on the exe then select properties under "Compatibility" check the option to run it in winxp mode.
you can also try to run it using 256 colors
Jun 15, 2009 | MicroProse Civilization 2: Test of Time...
Shrek 2 Activity Centree will not run on Windows XP SP3
I had this problem and I went to the Program Compatibility wizard in XP.
Start
Accessories
Program Compatibility Wizard
Choose from list
Select Shrek 2 click next,
Follow all of the suggestions that they give. They will walk you through each step to try.
I followed each one and found that Compatibility mode for Windows 98/Me with 640x480 screen resolution worked after I did the display adjustments listed below.
I went to Display Properties, Advanced, Troubleshoot, slid the Hardware acceleration all the way to the left and unchecked the enable write combining box. I had to restart the computer after I did this, but now the game loads.
Mar 08, 2009 | Shrek 2 Activity Center
Big screen Toshiba
there should be 2 plastic removable inserts below the screen that cover the screws. remove rhem with a fine bladed instrument
then you should be able to remove the screen.
Guy9
Jun 11, 2008 | Toshiba TZ50V51 50" Rear Projection...
Rhem 2 graphic card
May 08, 2008 | Computers & Internet
Region code Samsung BD - P1400
1. Make sure the player is switched on, and is at the Samsung logo screen.
2. Also check the tray is shut and that there's no disc in the player.
3. Now press the REPEAT button on the remote, followed by a five digit code.
4. This code is different depending on what region your player is *currently* set to: R1 - 29334 R2 - 38767 R3 - 56732 R4 - 76884 R5 - 53814 R6 - 24462 So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
5. If you've done this correctly (and your player is compatible with the hack), you should see a number at the top left corner of the screen corresponding to the current region.
6. Now, pressing any number from 1 to 6 will change to the corresponding region. Or, press 9 for "auto-region" mode.
7. Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD POWER) on the remote to close it and put the player into Standby mode.
8. The next time you turn your player on, the new region will be set. Don't forget that if you want to hack it again, you'll need to use a different code, as listed above. If it's currently set to "region 9", use the code for the last *proper* region you set it to.
or this...
Multi-Region on a Samsung BD-P1000 R2:
1. Switch on unit
2. Remove any disc
3. Wait fo NO DISC message
4. Press REPEAT on the remote control (NOT REPEAT A-B)
5. Type 57538 followed by the desired region number on the remote control
NOTE: 9 = Multi Region mode
6. Press OPEN/CLOSE on the remote control
Switch unit off
7. Enjoy :0)
Apr 27, 2008 | Televison & Video
Rhem 2 System requirements ok. Screen loads to menu. push play . next screen opens and when orange button automatically clicks, it says Macromedia Projector error... wrote down error sig C:\Docum~1HP...
When I checked the manual--the system requirements said to make sure i had QUICK TIME 6 FOR WINDOWS--installed. So I am going to try this----- they said to go to
www.apple.com/quicktime/
hope it works and gets rid of the big red X
Mar 25, 2008 | Televison & Video
Time Change
Using a Sportline but I'm an hour off with daylight savings time. How do I change the time, I can't figure it out. Can
Mar 10, 2008 | Sportline Big Digit Watch
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
