Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer ultimate care
The washer spins at the rinse cycle but the water doesn't drain. Sometimes the water starts draining but not totally.
  • 1,073 Answers
Check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Posted on Apr 23, 2008
Whirlpool Ultimate Care II is not draing properly and water is flooding out during spin cycle.
remove the hose up where it connects to the tub and see if there isn't anything stuck there,you could still have something stuck between the tubs and it usually will end up here or you could have a damaged pump from the piece of towel you pulled out of it or there's another piece still up in between the tubs and hopefully you'll find it at the hole where the drain hose is.
Jan 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Model #LSQ7030KQ0 Won't Spin
Either a bad lid switch or a bad clutch/brake on the transmission.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Not draining
what happens once it quits and you advance the timer back to a nother spin cycle does it spin or does the motor not start back
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
181 people viewed this question
Dan Webster
Dan Webster
Sal De
