When booting up my pc...message comes back - "Pri Master Hard Disk: S.M.A.R.T command failed"
  • 88 Answers
Go to the bios screen at startup and disable HDD smart .
typically this option is found under Advanced chipset menu. you enter setup by pressing F1, the 'delete' key or what ever key it says when you first boot the sytem. Go to Hard Disk Management or what ever they call on you cmos/bios/setup and shut it off. This will allow you to transfer what you need to back up.
Posted on Apr 23, 2008
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
I have a new Samsung SP0411N hard drive , I want to replace the hard drive but the bios say Pri Master Hard disk S.M.A.R.T . Command failed . Any help Please .
check your cables, if its ok,
check the jumper, if theres any,
try boot with only one hdd.
else, try consult to the manufacture for firmware update. there might a compatibility problem.
Oct 16, 2013 | Samsung (SP0411N) 40 GB Hard Drive
How do I back up my computer when this message appears Pri Master Hard Disk : S.m.a.r.t. command failed Press F2 to resume
restart computer and press delete button and in BIOS menu go to advanced menu set S.M.A.R.T disabled.
Jun 10, 2012 | Sony VAIO PCV-RZ44G PC Desktop
When I was trying to boot the system the following error is getting flashed on my screen and asking me to press F4 to continue. pri master hard disk: S.M.A.R.T. command failed
this is a warning your hard drive is about to fail
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 01, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Pri Master Hard Disk:S.M.A.R.T. Command Failed
You do not seem to have a smart capable hard drive, disable the setting in the BIOS by pushing F2
Jul 05, 2010 | Computers & Internet
Pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Whenever I boot I get the followoing msgs- pri master atapi cd rom primary slave ide hdd primary salave hd smart command failed no 1de master hdddetected press f1 to continue-- then okay But sometimes...
please change the wire connection in your pc from CD rom to HDD so that HDD become primary master and cd rom become primary slave, check after this, and if still get error check your IDE cable, and for the smart command fail may be your HDD didnt support smart feature, so disable this from advance setup
Aug 21, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Laptop was dropped hard drive grinding
Your diagnostic is correct, but there may also be some other problems.
Apr 05, 2009 | Averatec 3715 (A3715ED1) PC Notebook
http://www.tech-forums.net/pc/f77/startup-pri-master-hard-disk-s-m-r-t-command-failed-114514/
sounds like your hdd is failing, backup data by using external enclosure and get a new hdd.
try the solution in the link, it may get your computer to boot up.
Dec 20, 2008 | Averatec 3200 Notebook
Whenever I turn on my laptop it says "Pri Master Hard Disk: s.m.a.r.t. command failed"
This normally means that the hard drive is starting to go bad. Back up your data as soon as possible and if the PC is under warranty contact them for a replacement. For further information about the SMART error please see http://www.computerhope.com/issues/ch000184.htm
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
