Canon S900 - yellow light comes on and paper won't feed to print
  • swinfordl Apr 23, 2008
    I did find a little screw - where does it go?
  • swinfordl Apr 24, 2008
    Thank you so much - it's working fine now without finding where the screw went and doing the other things suggested - great advice! LSwinford
  • 19,396 Answers
You have paper jam
Posted on Apr 23, 2008
  • Ginko
    Ginko Apr 23, 2008
    First disconnect printer from power and usb.
    open all printer doors and inspect for small fragments of paper. Also turn printer upside down and check if there is a small part lost inside (eg screw).
    Close everything, connect to power and usb and restart.
    Check also that your ink cartridges are not dried up or empty.
    If is not the above then the printer may be faulty, in this case find a repair service in your area.
  • Ginko
    Ginko Apr 23, 2008
    Try if the printer works now that you removed the foreign object inside, the screw is not necessarily from the printer itself ( I often find 5 pennies coins, pins etc. inside printers) .
    If your printer works fine then the missing screw is either from outside the printer, or is not influing on printer functionality.
    If you still get the erro , and you ensured there is no paper inside, then only way I have to fix it is putting my hands on your printer.
    An inkjet has several hundreds screws inside, there is no way for me here to find out were it comes from.
    In this case may be time to get a repairman in your area.
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
The printer has flashing light, it rotates between yellow and green but never turns to solid green light, It does not accept any print job. Please advise
Issue: Power light (or Alarm and Power lights) alternate(s) between orange and green
Solution: The S900 may require repair
Unfortunately, the issue you describe seems to indicate that your product requires repair service.
Source:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/s_series/s900#ServiceAndSupport
You could try updating the driver, also available at the link above but the manufacturer's website seems definite that repair is in order.
Sorry for this news.
Dec 09, 2010 | Canon S900 InkJet Printer
Yellow light blinks 7 times
? Seven flashes: Defective printhead
Remove and reinstall the printhead.
Also, ensure that the protective cap has been removed. If reinstalling the printhead does
not resolve the problem, replace it with a new one.
Mar 04, 2010 | Canon S900 InkJet Printer
Hi my canon fax-jx200 keeps coming up recorded in memory..How do I retrieve it?? Many thanks, Lorraine
Hi Lorraine,normaly with this fax it have a auto print off setting that keep the faxes in memory.You can turn auto print to on by pressing the on/off button once less than a second,then it will switch to auto print on.
Let me know if you dont succeed.
Dec 03, 2009 | Canon FAX JX200 Fax / copier Plain Paper...
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannons450 paper jam- removed paper but yellow light keps flashing and nothing prints
At the printer icon cancel/delete all print jobs.
Turn it off by unplug the power cable, and the then turn it on.
If its still blinking, push once the on/off button or if there is any paper feed button
Sep 06, 2009 | Canon Office Equipment & Supplies
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
Canon pixma mp780 auto feed does not print
You probably need a new printhead, but that problem cann also be caused by the purge or cleaning station not working properly. If you do a cleaning cycle with no carts. and the little pads in the printhead come back with no ink on them then the purge is working and you need a new printhead.
Aug 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
No ink coming out on my Canon S900
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jun 29, 2009 | Canon S900 InkJet Printer
Canon S900 printer, 3 orange 1 green flash?????
Maybe the sensor are blocks by dust.Clean also ur cartridge,because ur cartridge was rest for weeks.
May 19, 2009 | Canon S900 InkJet Printer
41 people viewed this question
k24674
jasbo
jasbo
