All my printers that are displayed "paused off-line" message
    Genius:
  • 1,447 Answers
Hi birdlee155. If that doesnt delete the print job do this
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) right click Print spooler, click on stop, right click back then click on start.
5) Close Services Local
Restart computer
then try to print again
update me if it will not work still
Posted on Apr 23, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 23, 2008
    If you are getting an error message that states USER INTERVENTION REQUIRED or USE PRINTER OFFLINE, the printer driver may have become disabled. Please follow the directions below to resolve this issue.
    Please note that the printer must be in an online state
    WINDOWS XP
    1) (a) Click START select CONTROL PANEL and click on PRINTERS AND FAXES.
    NOTE: If you cannot locate PRINTERS AND FAXES, Follow 1(b).
    1) (b) Click START select CONTROL PANEL double click PRINTERS AND OTHER HARDWARE, and click on VIEW INSTALLED PRINTERS AND FAXES.
    2) Highlight the icon of your printer with a single click.
    3) Click on FILE.
    4) The only check mark showing should be beside SET AS DEFAULT.
    5) Ensure that there is no check mark beside PAUSE PRINTING or USE PRINTER OFFLINE.
    6) Simply click on the check marks to remove it.
    7) Try printing.
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
The message "head open " printer idle v53.16.5z
Try taking the printer off pause. It should clear the error.
Mar 03, 2011 | Zebra ZM400 Thermal Label Printer -...
JAM LABEL
1. Turn the printer on and make sure that the LCD display reads 'ON LINE'.
2. Press the PAUSE key once. [The display will read 'PAUSE'.]
3. Press and hold the PAUSE key until four or five labels feed forward.
NOTE: On some models, pressing the pause key will change the LCD display to 'TRANSMISSIVE'. If this happens, repeat step 3.
4. Press the RESTART key. The printer will go back ON LINE.
5. Open the print head and reposition your labels, so that they are ready for printing. Close the print head.
Nov 17, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Sx4t labels gap setting
1. Press the [PAUSE] button. The display shows the printer is in PAUSE mode.
2. Press the [PAUSE] button again. If the display shows TRANSMISSIVE then release the [PAUSE] key.
3. Press the [PAUSE] button again. Labels will now start to feed through the printhead. After 5 or 6 labels have gone through, release the [PAUSE] key.
4. Press the [RESTART] button.
The printer should now be on line and if you press the [FEED} key, 1 label should be fed through.
Aug 21, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Power, pause and error lights are on. No message
The logic board is blown and would need to be replaced. Have it repaired asd there is nothing you can do.
May 14, 2010 | Zebra Z4M Printer
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Printer is stuck on error message and pause
The printer frequently displays an error message and will have the pause light on
Jan 26, 2009 | Zebra Z4M Printer
307 people viewed this question
k24674
jasbo
jasbo
