Question about Lands Phones
Not able to see caller ID on phone receiver on in coming calls.
  • poconan Apr 23, 2008
    I realize if someone is hiding the phone # it will not appear on phone s caller Id. I was getting the numbers and names before, all of sudden it stopped. I like to screen the calls.
  • 563 Answers
Hi poconan
Not really much you can do about this one.
If the other person is hiding their caller ID , there is just about nothing you can do to stop that.
Posted on Apr 23, 2008
  • 19,396 Answers
The caller may be in protected mode
  • 1 more comment
  • Ginko
    Ginko Apr 23, 2008
    If you do not see anything on display then you have a faulty display.
    If some caller is not displayed, that is because the caller is in protected mode.
    If you do not see any caller number at all, but you can read other info on display, then check your phone manual, go to phone settings, select 'reset to factory default settings' on menu.
    If this does not fix it then the phone is faulty, in this last case you may try doing a firmware update or taking it straight to a service shop.
    I can be more specific and provide you with phone manual if you post your phone make and model. I will be offline for a while can post reply in a couple of hours.
  • Ginko
    Ginko Apr 23, 2008
    Did you eventually read my post, evidently not.
    good luck
  • Ginko
    Ginko Apr 24, 2008
    If you want to hide your screen name you go to phone settings and set hide number
4 Suggested Answers
SOURCE: caller-id quit working
This is a followup to my earlier suggestion. My caller id is working. So, the culprit had to be related to the 9V battery. Just try my earlier solution from 1/20/07. If it works..fine. If not, bye-bye to the phone.
Posted on Feb 10, 2007
CORDLESSGURU
  • 106 Answers
SOURCE: Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Posted on Feb 10, 2008
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Posted on May 11, 2009
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
I just received KX-T7730 phone with an LCD screen and it is not showing the caller ID # that is dialing in. It only displays CO 1. The previous phone similar to KX-T7730 shows the caller id #. So how can I...
The one who can show the caller ID when someone call is the caller only. He/she can set to hide his/her number ID in their phone so we can't see it. We can't force to see this caller ID, but if this calls disturbed you, you can install call blocker and only allow certain incoming call to be recieved.
Hope his help and rate please.
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Caller ID Stopped Working
I had the same problem - until today. Seems that the phone jack wiring in my living room needs repairing. Receiving and making calls is no problem, but the Caller ID is first to go (according to phone service provider). I tried out the phone in the bedroom, and the Caller ID shows up fine. Serviceman coming tomorrow to fix the L/R wiring.
Jan 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
Can't receive incoming calls
same here... I unlock it but it doesn't received call
Aug 16, 2008 | Motorola Mobility A1200
Some calls are coming through as "unknown number" on my LG U990, despite the callers having ID sent selected on their phone.
Some network providers are having trouble with caller id. You need to be sure that friends or callers are not putting code for unknown caller. Automatically You receiving as unknown calls.
Check Your phone on setting caller id click on show.
Jul 23, 2008 | Cell Phones
Caller ID
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Lands Phones Logo
78 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
