Question about Sony KP-53HS10 TV
SONY KP53HS10 BLINKING 5 TIMES
I AM HAVING PROBLEMS WITH THE TV LISTED ABOVE. THE PICTURE BLINKS ON AND OFF.
THE LED IS BLINKING 5 TIMES.
CAN YOU TELL ME IF IT IS REPAIRABLE?
  • candyttv Jul 22, 2008
    I have a KP-53hs10 and the picture blinks out randomly for a second and then comes right back. The stand-by light blinks 5 times.
ctf1800
  • 4402 Answers
SOURCE: Sony KP53HS10
Five blinks means "Video out abnormality detection". Possible problem areas are as follows:
Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510, 516, 524 (A board).
There are actually three C boards, the CR, CG and CB boards. They are attached to the rear of the red, green and blue CRTs, respectively. I wouldnt attempt to repair the set myself. I would solicite the services of an authorized Sony servicenter.
Posted on Jan 23, 2008
  • 4 Answers
SOURCE: Sony projector kp53hs10
I recently had this same issue. If you remove the speaker pannel in front of the set, you will see a block with 6 knobs on it, just to the right of the center panel. This is called a focus block. 3 knobs on top which control the voltage going to each tube, and 3 on the bottom are for fine tuning focus for each tube.
If your problem is the same as mine, it is a convergence problem. and due to the fact that the picture is turning off, says that one of the tubes is not getting enough power.
NOTE: BE CAREFUL NOT TO TOUCH ANYTHING ELSE BUT THE FOCUS BLOCK, THERE IS EXTREMELY HIGH VOLTAGE WITHIN THE TELEVISION, AND CAN CAUSE SERIOUS INJURY.
1. Make sure the screen is blank, ex video 2 with nothing on. It's easier to tell.
2. very slowly, one at a time turn up the knob on the left top, should control red, untill you start to see lines come on the screen, then turn back just till they dissappear, and you see a black screen again.
3. continue with the second knob on top, just the same as the first.
4. And continue with the 3rd knob on top right just the same.
5. when you're finished, turn off the set, then back on, let is set for a min or 2, then hit the FLASH FOCUS.
If the problem persists, it most likely is a IC chip.
Best of Luck
Ken
Posted on Dec 03, 2008
SOURCE: my sony kp53hs10,the standby light
I've got exactly the same problem. Initially, I saw it flashing twice, pause, twice, pause, twice... I pulled the plug when it failed to respond at all. And then when I plugged it back in, it went into the continuous flashing mode. Halp!
Posted on Feb 03, 2009
  • 6 Answers
SOURCE: sony kp53hs10
Try (with your remote) hit Display + Channel 5 + Volume - + Power hit each key within 1 sec of each other and the tv should go into error check mode on the screen and display some data, record that and google.
Mike
Posted on Mar 01, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: Sony TV standby blinks 5 times picture comes and goes
TRY TO TURN SCREEN CONTROL UP OR DOWN
Posted on Aug 26, 2009
Sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
Jan 14, 2015 | Sony Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture and a blinking red light
    Please count the number of LED, that how many times it flashes in a specific time period. Numer of LED blinks doente the specific problem in specific area. Therefore, first count the LED blinking for example 2 times 3 times.....up to 10 times. And then post your problem again or reply me. Then i will be able to tell you the solution.
    Thanks for using fixya.
Oct 31, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Repair inquiry
     According to the LED BLINKING there must be some problem that are given below:
Diagnosis item:  Video out abnormality detection
TIMER/STANDBY
Indicater
Number of blinks:
5 times
Supposed malfunction:  Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510,516,524 (A board)
Condition:TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
Self-diagnosis
screen display,
Diagnosis item: Results:   5 : AKB 000
So, This was the result of 5 times led blinking.I would suggest you to please contact any expert or strongly recommend to contact any SONY SERVICE CENTRE for repair because it's not an easy job to rectify this problem. Hope you better understand my sayings.
Thank you for using fixya.
Nov 29, 2008 | Sony KP-53HS10 TV
Picture is all red and led blinks 5 times
Most likley bad tube have replaced alot of them on this make and model.
Sep 02, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KDF- 42WE655 Blinks 6 times No picture or sound
was there a smell? it might be main transformer the front blinking led means the set in is safety mode and wont boot up because of a fault
Aug 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Sony KP53HS10
Dec 30, 2007 | Sony KP-53HS10 TV
Husband died and took the manual with him?
Hi. TRY THIS. CHECK THAT ALL THE CRT TUBE BASE PCBS ARE PROPERLY SEATED ON THEIR PINS, IF ANY BECOME DISCONNECTED THE AKB CIRCUIT SHUTS DOWN THE POWER SUPPLY. This is a simple job to do the hardest part is removing all the screws from the rear of the set.
Sep 15, 2007 | Sony KP-53HS10 TV
Sony KP-53HS10 TV Logo
83 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
