Question about Samsung HCM5525W 55" Rear Projection Television
Samsung tv problems
How much did they quote. I'm in the DC area, it'll probably be more expensive around here. thanks, and what company hopefully they're national.
I've tried to contact a service company recommended by Samsung based on my zip code. They haven't returned my calls yet. How much can I expect to pay for replacing one bulb in my rear projection TV? Thanks.
Posted on Apr 28, 2008
My Samsung plasma tv got hit with a remote. Cracked in a star pattern now. It was on when it happened. Screen went black but still had sound. Turned it off and then back on and now no sound and black...
Most likely. It is probably in some kind of protection / "get me repaired at a really high cost" mode, this would explain why you had sound until you restarted it and it ran a brief diagnostic.
I don't think you'll be able to claim this on warranty as it is accidental damage, not a manufacturing error, but you never know! Maybe your home insurance will cover it.
Call Samsung and see what they say, the might be able to repair it for you or quote you the cost of a replacement.
Thanks
Moza805
Aug 31, 2011 | Samsung PN50C450 50 in. TV
Samsung Volume
Hello there.
Please use the volume control on the side of your handset, to increase the volume.
Notice on the picture here when the volume control is located.
Hope this helps.
May 22, 2008 | Samsung SGH-D600 Cellular Phone
My Samsung SGH-a877 touch screen does not respond to "touch" nor "tapping". The touch screen has always been flakey. Now the screen is totally dead. The slide out keyboard &...
Usually when touch screens don't work, it is due to water damage. You can bring your phone to your carrier's nearest store and ask someone that works there to check if your phone suffered water damage. They'll check the inside of your phone. If that's the case, you'll probably have to buy a new one. If you're insured this shouldnt be TOO expensive. But if you bring it to the store and it's NOT water damage (perhaps a software issue), they should replace the phone for free!
Hope this helped
Please rate my solution!
- Frankie
May 02, 2011 | Samsung SGH-A877 Impression Cell Phone
I have an Samsung LE52B750 TV that it has horizontal lines and a double image on the right side of screen. Of course it is out of warranty. Does anyone know what this problem is?
Hello, it sounds like one of the display boards has gone. Its probably not the screen as you wouldnt get any picture at all or very little. Even though it sounds expensive, most of the work is in dismantling the tv. These days its just a matter of replacing a board or two. Get two or more quotes and pick the best one. I hope I have helped.
Mar 24, 2011 | Samsung Televison & Video
The screen on my lg 42pc1da tv is cracked is it cost efective to repair or replace the tv
That's a tough one to answer with constantly changing prices, and different prices in different areas, but in most cases, a plasma screen is more expensive to replace than the entire unit (especially if you move to LCD or another technology).
You'll have to call around your area and see what places quote you for a new TV and what shops will charge to get you a new screen.
Mar 19, 2011 | LG 42PC1DA 42 in. Plasma HDTV
Blank display on Saumsung T10
The only way to get the unit working is to press the reset. I have the same problem, also the main menu is very slow.... this is my experience from Samsung.
I took it back to Samsung, the first lady charged me $35 as deposit and told me that if I decided to fix it they will then take the $35 off the total. And if it cost too much to fix they’ll return my deposit. The same lady called me two days later saying there was something wrong with the PC board (I already know that there was something wrong, I just needed a quote on how much it’ll cost to fix the unit) and that it’ll cost me $238 plus labor to fix it. I was like no way I don’t want to do that I’ll just get a new one for $90. So the next day I rock up to Samsung Service Centre- Granville (ICURE) to pick up my MP3 and deposit, a second lady was there and guess what she didn’t give me back the $35, saying that it was a charge for quoting. That really pissed me off… I’m never buying another Samsung product.
So I hope I’ve save you guys from getting ripped off on the quoting.
Mar 20, 2009 | Samsung YP-T10 Digital Media Player
Green shading appears around faces of people on the screen
Try adjusting your TINT control in the menu.
IF the problem seems to be in a surtan area of the screen, the light engine is bad. This is very expensive to fix. You might want to buy a new tv.
Jun 21, 2008 | Mitsubishi WD-62327 62" Rear Projection...
VE175b 17" LCD No power.
Do you live on the second storey or higher? Couldn't resist. =)
It will probably be the capacitors on the main powerboard inside the monitor. Its a common fault with these and is easy to get repaired.
Unless you have fairly good electronics knowledge though you are best to take it to your local TV repair shop. The voltage inside reaches points far higher then even what you have in the wall sockets of your home.
The repair should not be expensive in any case. Call around and get a few quotes, also check who will service an LCD in your area, some will some wont.
Hope that helps =)
Apr 16, 2008 | ViewSonic VE175b 17" LCD Monitor
Phone connection problem
Yes, it looks like the thunderstorm has damaged your DTV unit because the DTV unit should only go off hook as a means of dialing the DTV Company. I would have that unit replaced. BTW, do not try to repair that DTV unit. I work for a Telephone company in the Maryland DC area and I can tell you there are no serviceable parts inside and the unit is not your to do that anyway. So call the DTV Company and have then replace the defective unit.
Aug 31, 2007 | Samsung SIR-TS360 DirecTV DTV Receiver
Samsung HCM5525W 55" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
