Question about Maytag Atlantis MAV6260AWW Top Load Washer
Maytag atlantas top loader water keeps dripping from top of drum
My washer will keep on dripping/light spraying of water from the top of drum even after filling cycle complete and sometimes when off.
  • Anonymous Mar 17, 2014
    water sits in top loader under drum
  • Anonymous Mar 19, 2014
    Loading water into the drum
  • 5,911 Answers
Your water inlet valve is probably leaking by. If the water pressure is too, or if there is sediment build inside the valve, sometimes the solenoids will not close properly. Try cleaning the valve to see if this helps. If not, I would recommend replacing it. Depending on which valve you have, repairclinic.com has two listed for this model washer for $20 to $30. Let me know if this helps, or if you need further assistance.
Posted on Apr 23, 2008
    Genius:
  • 1,073 Answers
Replace the water inlet valve
MY MAYTAG FRONT LOAD AT TIME WILL FILL WHEN WASHER IS NOT ON OR WILL DRAIN AND SPIN ON IT'S OWN
It may be the water inlet valve is not shutting off the flow 100%. If water keeps trickling in, even dripping, it will eventually fill the drum. Some models have a water level sensor that will run unit thru a drain cycle to prevent an overflow situation. Try checking the unit every 6 or 8 hours to see if there is a slow build up of water accumulation. Replace inlet valve if there is.
Dec 26, 2014 | Maytag Washing Machines
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My 10+ year old Maytag Neptune washer has standing water behind the drum after the spin cycle
Griffin is correct but, I took it one step further and removed the front cover and rubber gasket and used a long thin brush after spraying white vinegar with a spray bottle and cleaned all the **** from around the drum. I use white vinegar with clothes once in a while to keep the drum free of built up soap and softner.Its a little work but trust me when you see all the stuff on the drum you will understand why the machine stinks. I also leave my soap tray door open all the time to allow air inside.
Oct 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
MAVT734EWW washer's water level not working, will just keep filling the drum and not stop even when open top door or click knob to off, have to turn water off at the source
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.Replace the water valve with this part.
Nov 30, 2010 | Maytag Washing Machines
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
I have a neptune front loader and I have to pretreat every item before washing. My clothes do not come clean..I have contacted Maytag several times but no one has ever replied. Can you help The repairman...
Look up the model unit and compare it to the models appear on countless Google search pages. I had a set that bought new after the introduction and what became a PR nighmare for Maytag as they tried to ignore the problem. I was unaware of any problems since there was never a recall just at the very end when they offered to take the nice looking front loader in exchange for a new regular top loader. Mistake number 2. My washer started to get a bad smell and being single and doing maybe three loads a week. Then the washer drum started retaining water, not inside, but surrounding. The only way I discovered is while cleaning I turned the drum. Depending on who you asked, even some Maytag salesmen as well as the folks at the big home improvement stores and it was said to be the "oil" that lubercates the drum, water that was needed to turn the drum and a couple referenced this whole manufacturing defeact that could not be fixed. I decided I would stick with the oil or water concept becasue it made sense. One evening, I Googled. I was sick. It would only get worse and to contact Maytag, was a joke. Instead of waiting for the day to come, I listed the dryer for sale with the washer free. I disclosed everything and I could have sold a100 sets. The lady who bought the set for $650 was putting it to a flip/rehab project. I hope you are not the one who bought her property -- she wasn't planning to go into detail with the future buyer,
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Atlantis MAV6260AWW Top Load Washer Logo
195 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
