Question about Garland H283 Gas Kitchen Range
I have GE Sealed glass 36' stove top 1 of my knobs that turns the flame on is broken. I have the original book with the model # on it JGP636 or JGP960 on your web site it only give me valves not the knobs The # on the back of the knob is KIPB56 191D2828 I have put all numbers and the wrong knob comes up. On the back of the knob that sits on the glass top is flat on one side and roung on the other. The newer models are all oval somewhat.How do I go about ordering the part I need
  • 4ced2registr Jun 04, 2008
    I have the same problem ... plastic knob is broken at the stem that
    connects it to the valve. Broken molded part has KIP5B56 191D2828
    inscribed on it. KIP5B56 and 191D2828 are probably a plastic part
    vendor's and GE's part numbers respectively.
  • 4ced2registr May 11, 2010
    Knob is black in color.
AH ha, I found one with these guys after a painful online hunt. I hope this helps. it was like $7.57 after the cheapest shipping option. but you can get the part number from the same link and keep hunting. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214753
Posted on Jul 20, 2008
    New Friend:
    Genius:
  • 1,073 Answers
What color is the knob
Posted on Apr 23, 2008
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
How do I repair A knob that is broken off at the stem of my ge profile flat top stove?
You cannot repair this switch, you will have to replace it.
You will need to remove the cook-top and remove the glass top to access the switches. There will be a series of screws around the underside of the lip of the glass top that attach it to the burner box. Remove all of the remaining knobs and lift the glass straight off the box.
I would get your model number and order the replacement switch before starting the process.
good luck!
Jun 16, 2010 | Kitchen Ranges
Ge cooktop jgp636 : water leaked onto the igniter switch. It started to click, click. Finally there was a spark, and flame,under 2 of the 5 switches. Then when I tried turning on one of the unaffected...
you might have shorted out the switch which caused it to burn...you can change all the switches buy ordering from searspartsdirect.com put in Model # and search switch...you probably gonna need some serious wiring..i recommend call the tech
Oct 27, 2009 | GE Profile JGP636 Gas Cooktop
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
Low flame on gas top burner
Hello Husky!! We can help you get the correct parts to repair this wonderful range. You sin=mply need another burner head to be replaced. We have parts and will make sure we get this out to you asap so you get back up and running soon. How many burner heads would you like to order? Please call or email us asap and we'll get these parts right out to you. We look forward to working with you. 972-859-0929
Feb 01, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra glass top stove.
Two possible reasons come to mind.  1. There most likely was a short circuit that activated the top unit. Was any part of the top glowing when you looked at it while it was crackling?
2. Be aware that glass tops CANNOT take as heavy a load of pots and pans as a STANDARD range can. The glass will crack. The stress can accumulate over a period of time and you will be left with the 4 am  madness dim experienced.
If anyone out there finds themselves in a similar situation, don't wait when  you hear the crackling. Pull the the range plug, or find the ranges circuit breaker in your electrical box and turn it off.
Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Garland H283 Gas Kitchen Range Logo
833 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
