Question about Maytag Neptune MAH7500WH Front Load Washer
Maytag Neptune hot water wont shut itself off during ENTIRE cycle!
Here's a new one....the hot (only hot) water stays on, even if unplugged! We had to shut off the supply.
  • 5,911 Answers
The water inlet valve is probably defective. There's two solenoids on the inlet valve. One controls the cold water, one controls the hot water. This is also known as a "mixing valve" on some washers. There are a few things that can cause this problem:
1. Water pressure on the hot water tap is too low and not closing the solenoid diaphragm all the way (minimum pressure should be between 10-25 psi).
2. The filter screen on the hot water side needs to be cleaned thoroughly.
3. Valve is defective.
If you have tried cleaning the screens, and have never had water pressure problems before, I would bet the valve needs replaced. I could not find an exact match for the model number you provided, but repairclinic.com has Maytag Neptune parts. Double check your model number and use the search feature on the website. There are two water inlet valves listed there. Depending on which one you have, it can cost between $30 and $74. I hope this helps you. Post back if you have any further questions.
Posted on Apr 23, 2008
Washer wont pump out the water and wont shut off if not unplugged
Heres a great website: Go there and investigate the videos
http://www.repairclinic.com/Shop-For-Parts?SearchText=Maytag%2520Neptune%2520FAV6800AW
Feb 18, 2015 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water will not shut off on its own even after the entire wassh cycle is done
There is a water pressure sensor that can tell how full the washer is. This is probably the culprit, as the water is now just cascading into the exhaust system. What causes the thing to stay on is a collapsed microswitch in the sensor biscuit, or the tube leading to it is clogged. Have this level switch looked at.
Nov 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Sep 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah4000aww, tub overfills
Have you changed your door latch wax motor yet... If you have the brown actuator pin then you want to chuck that wax motor out of there quicker than spit! You want the redesigned wax motor with the black actuator pin. I know of folks where the wax motor failure caused the timer and /or water valves to act up... See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
Jul 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune mah4000aww belt wont stay on drive wheel
lost you on chat you closed the window
plz email me
Mar 03, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH7500WH Front Load Washer Logo
248 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
