Question about Cuisinart BFP-703 SmartPower Duet Food Processor
Lights are on but it wont run - Cuisinart BFP-703 SmartPower Duet Food Processor
  • Gavgray Apr 17, 2009
    The motor suddenly stopped working during use (in between pulses - so on, then off for few seconds, then would not turn on again).  The interface lights up like normal but the motor does not at all engage.  I am thinking I blew the fuse (if it has one) but I'm having trouble taking the unit apart, particularly loosening the shaft so I can take the whole thing out of the casing.  Nothing looks fried on the board, as would be expected.  The blender did seem to eminate that "burning motor" odor when it ceased to work but the odor was subtle.
  • 8,596 Answers
If you have had your blender/food processor for less than 3 years, call Cuisinart and get it repaired in-warranty. You can find a new BFP-703 from $80-$100, and even an in-warranty repair will cost you $20-$30 in shipping (just food for thought). If you are Out Of Warranty, let me know, and I can give you some diagnostic assistance - if the shaft is just locked up, and can be oiled, that is a pretty easy fix. Anything else wrong with the unit is going to be tricky, since original internal parts are not available for sale.
-Tha Mp3 Doctor
Posted on Mar 17, 2009
  • 1 more comment
  • kelvin613 Jan 05, 2011
    I have the same problem and no, it is not under warranty. The shaft still spins but I can`t seem to remove it from the housing. The gear attached to the top is permenantly attached to the shaft and wont allow you to pull the motor out. I just need to know where the fuse is located and how to remove the motor from the unit.
  • Kentin Sep 15, 2011
    Me too, Kelvin. Looking for the fuse, but can't remove the motor. Anyone?
  • srearoyl Sep 15, 2011
    to get the motor out, you will have to take the clutch out (the black thing that spins on the top). it is threaded counter clock-wise. It comes out easily after that.
    I replaced the thermal fuse once, now I need to do it again...looking for the correct fuse now.
Thank you very much. I will give I a try
Posted on Sep 16, 2011
Hello there my food processor will not spin hear motor running lights on to go but no spin??
Post model no on line probably the rubber drive on the motor
they fall apart over time.found on line about 3or 4 dollars
Jun 19, 2015 | Kenmore Food Processors
Why wont the blade turn
Something is damaged, worn out or broken.
Sep 17, 2014 | Food Processors
I press a button n it blinks then all the buttons start blinking and the motor never starts.
The motor is most likely open circuit. Solutions are going to be either replace the motor OR if the thermal fuse on the windings is blown you will need to get one of the same value and replace it. The value is written on the fuse and it is under some fibreglass tape on the field winding with the aluminium clip around it. You need to remove the motor completely to do it.
Jan 05, 2014 | Wolfgang Puck Bistro 620 Food Processor
Hamilton Beach food processor
make sure bowl and lid are on correctly. If not, it wont run. Both have safety switches where they lock onto the unit. If latch tab is broken, you will need new bowl or lid. If still nothing, switch itself is bad
Jun 28, 2013 | Food Processors
KitchenAid KFP740 9 Cups Food Processor: I used my processor last in September, 2010 to blend tomatoes for salsa (it was working just fine). When I tried to use it again in Dec., 2010 it simply wouldn't...
Most likely it will be to do with the bowl or the lid. The safety mechanisms in both parts are likely culprits, they operate a micro switch just above the switch panel and hidden by the base of the bowl. Have just the bare motor plugged in and turned on with the run button depressed. Now with something plastic depress that small black button, the motor will likely start running. That proves motor is fine and you need to figure out which of the bowl or lid is the faulty part. The pusher needs to be in the lid tube before the motor will run in case you have forgotten.
Apr 09, 2017 | KitchenAid KFP740 Food Processor
Wont run
I've had a similar problem. If you open up the case and examine the wiring you might find that there is a loose wire right next to the switching mechanism. Solder the wire back on and the chopper should function. I've had the similar issue, my chopper was accidentally dropped & stopped working after that. After I soldered back the short wire, chopper came back to normal operation. Hope this helps.
Feb 08, 2010 | Ultimate Chopper Food Processor
My food processor wont start?
plz contact 022-23051554 \ 23095757
Feb 02, 2009 | Food Processors
Lights all Come on, Then spins up a few seconds then dies
Remove work bowl completely - then try the various buttons. If no spinning occurs with work bowl removed, the motor is dead. Find out from Cuisinart if you are still under warranty, and send in for repair.
Jun 08, 2008 | Cuisinart BFP-703 SmartPower Duet Food...
It won't start
The power lights go on put the machine does not run.
Nov 22, 2007 | Cuisinart DLC-5 Food Processor
Cuisinart BFP-703 SmartPower Duet Food Processor Logo
1,116 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
